c5 engine
mm1
c5 engine
Unread post by mm1 »
hey guys.i have a c5 2.0l hdi.the other day my car just died out going along the
motorway.seemed to be alot of smoke from the exhaust in the process.
took it to local mechanic and he says either a piece of a piston broke or
else a ring.can this engine be repaired or is another second hand the way to
go.the car is 2003 and has 180,000 miles on it.any advice greatly appreciated.
x 1055
Re: c5 engine
Unread post by wheeler »
first you need to know exactly whats gone wrong with the engine to know if its repairable. If a bit of the piston has broken then unlikely repairable. Best to get a borescope down the injector hole & have a look.
jgra1
(Donor 2021)
x 36
Re: c5 engine
Unread post by jgra1 »
and / or have a compression test done ..
but another engine would be my choice if yours is gone.
interested to know what happened to it..
john
mm1
Re: c5 engine
when i took of the oil filler cap there is alot of pressure and alot of steam coming
out.mechanic says it is either a piece of a piston broke or else rings.either way he says
fixing my own was not the way to go.so its make up my mind time.either get rid or get a second hand engine.
can get one about 2 hours drive away,it has 110,000 miles and cost 450 euros,is this price and mileage a bit high.it is
out of a 05 reg and mine is a 03 reg,are these compatible?
x 1240
Re: c5 engine
Unread post by Peter.N. »
I would say from the symptoms that your mechanic is probably right. I don't know where you are but here you could probably pick up a good secondhand engine for less than the cost of stripping yours down to find the problem.
http://www.ebay.co.uk/itm/CITROEN-C5-2- ... 1e7a850035" onclick="window.open(this.href);return false;
mm1
Re: c5 engine
hey peter.i am in the south of ireland,county limerick.i have been out in the car there for the last hour
and check the oil filler cap again.there is still a fair bit of steam out of it and spitting out drops of oil.
the car takes only a couple of seconds longer to start than it used to,but other than that you would think
there is nothing wrong with the car.this is probably a stupid question,but is there any chance that steam
and pressure is normal and there is nothing wrong with it?
mm1
Re: c5 engine
forgot to ask,is the engine in a 05reg the same engine as my 03reg,thanks?
taffy
Re: c5 engine
Unread post by taffy »
turbo seals?
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
Ben82
x 7
Re: c5 engine
Unread post by Ben82 »
mm1 wrote:forgot to ask,is the engine in a 05reg the same engine as my 03reg,thanks?
Whilst I'm no expert, looking at the 2.0hdi for the MkII and the MkI on service.citroen.com, it would seem not. The MkII has RHR or RHL (both 138) as the marking, whereas the MkI has RHZ (110) or RHY (90). This also documents the changes to the engines :)
2004 Citroen C5 3L V6 Auto
x 1240
Re: c5 engine
If it was a broken piston ring or piston I would expect it to only start on 3 cylinders, it might run OK on 4 once its started, is it doing that? The difference between the engines is I believe that the early one was 8 valve and the later one 16 valve, I would think an 03 should be an 8 valve, the changeover point was around 05. Look at the rocker cover the 8 and 16 valve are different.
SwissSPEC
Re: c5 engine
Unread post by SwissSPEC »
Just to clarify, the engine didn't start to overrun did it? what i mean by that is that you take your foot off the throttle & the revs continue to rise to their maximum with tons of white smoke coming out of the exhaust. If that happened, it means an injector has failed.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
mm1
Re: c5 engine
thanks for the replies lads.looks like im going to have to rule out the 05reg engine so.the same fella has a 03 engine anyway.
no the engine never over ran.i was going along the motorway and the engine made sum kind of a
funny noise and just cut out.
mm1
Re: c5 engine
hey peter.ya it feels like it srarting on 3 cylinders,slower and rougher than usual.but then feels like normal when its started.
x 1240
Re: c5 engine
Many years ago piston failure was quite common, a ring would break and work its way up the piston until it emerged on the top, there would then be a loud knocking noise as the piston continually rammed it against the head, usually leaving dents in both, replacing the piston usually effected a cure but parts were much cheaper in those days and engines much dearer.
taffy
Re: c5 engine
well my fuel pump jammed up other day and it caused engine to just stop....untill I got belt off I thought it could have done something like that...sound could have been rockers snappin? Do u trust ur mechanic?get a second opinion...get The cam belt off
