Thinking of buying from a private seller. Last MOT earlier this year mentions light misting at passengers side front suspension. It has the hydractive III suspension so not sure what to make as if I saw that sort of leak on a conventional absorber I would most likely replace it. Was quoted £190+VAT only for the part from Citroen plus around £150 for fitting.
How can I tell if it really needs replacing?
Many thanks
C5 08 exclusive front suspension misting
osx
- x 15
C5 X7 Exclusive 2.0 HDi Auto
- x 1240
Re: C5 08 exclusive front suspension misting
Unless its leaking substantially I wouldn't worry about it, if it is it will fail the MOT anyway. You should be able to get a good secondhand one for not too much money.
osx
- x 15
Attached a photo after some cleaning. Will check again after a couple of days to see what it looks like. How can I tell if it is significant or not? Will I be able to feel anything while driving?
Trying to make the photo smaller but seems to revert to full size everytime!
- x 1240
It won't make any difference to the drive, the main problem would be loss of fluid but it will look quite wet if that is happening.
osx
- x 15
Thanks Peter. If the only problem is replacing some fluid once in a while then I will probably just leave it and clean it before MOT. The only other thing is that one of the bushes on the same side needs replacing and if it means taking the whole suspension apart I might as well replace the strut. Where can I find a second hand one?
Think the bush that needs replacing is the one in the dark circle
- x 1240
If you don't have any scrap yards near you have a look on ebay for C5s being broken, usually under 'spares or repair'
http://www.ebay.co.uk/itm/Citroen-C5-Mk ... 3a7a6655ab" onclick="window.open(this.href);return false;
osx
- x 15
This is not the part. Hydractive means no springs
- x 1240
Sorry, another senior moment
My brain sometimes becomes detached from the rest of my body
osx
- x 15
Can't seem to find any used parts anywhere. All quotes I received were for non-Hydractive struts
osx
- x 15
Does anybody know how difficult is it to replace that bush?
Xantippa
- x 29
I got struts replaced on mine under warranty. They were leaking, and another one also made some noise. It seems that there´s extended 5 years warranty for front struts, if car is driven under 200000 km, and is manufactured on right date. Go and ask local Citroen dealer weather your car is entitled for the warranty or not. There´s not very much time for these -08 models...
If warranty doesn´t cover, here´s some cheap struts: http://www.accessoires-citroen-lorient. ... g=1&p=2186" onclick="window.open(this.href);return false;
osx
- x 15
5 years will be next month so need to be quick! My impression however was that the warranty was for 3 years or 120k miles and 5 years only if extended warranty is purchased.
OnlineHell Razor5543
- x 3306
Sometimes, when a design flaw crops up, manufacturers extend the guarantee. I have an Xbox 360. About 2 years after I got it, it did the "Red Ring of Death" (NO it is not the after effects of a curry!). I found out that Microsoft had (for this fault) extended the guarantee from 1 to 3 years. I got it sorted, free shipping, and they replaced the motherboard and DVD drive.
dfinglide
- New User
Might be a cracked fluid return line,it runs from the bottom of the strut up to a steel pipe on the inner guard. Jacked up my C5 to do an oil change, rubber hose snapped and fluid all over the garage floor, @ $25aud/litre, NOT happy !!
- x 94
were are you located
try this company for used parts as they are cit/pug dismantlers
http://www.pcr767676.co.uk/" onclick="window.open(this.href);return false;
Regards, malcolm.
