map sensor
Chiinkian
New User
map sensor
Unread post by Chiinkian »
hi i am looking for a map sensor to fit my xm 2.5 t d 1997 if any one has got one or knows were i can aquire one could you let me by email or phone on 0~7~5~3~1~9~6~6~1~6~6 thanks john i live in derbyshire
x 695
Re: map sensor
Unread post by Mandrake »
As far as I know diesels don't use a MAP (manifold absolute pressure) sensor as they don't have a throttle plate to generate a vacuum...
Or do you mean a hot wire MAF (mass air flow) sensor ?
x 5674
Re: map sensor
Simon,
couldn't say if it was universal on diesels but mine has one on a little tube off the intercooler.
Citroen don't call it a MAP sensor but that is what it is. This is in addition to the MAF.
Before the MAF was changed there was also a fault code indicating a defective MAP sensor.
Replacing the MAF restored the performance and I never got around to replacing the MAP, which may well still be defective.
Possibly why my economy is rubbish, come to think of it.
x 8391
Re: map sensor
The 2.5 does as it's got a Bosch Electronic pump on it, The Bosch version of the Lucas EPIC, so it will...
John, go and have a look over on Club-XM as there are a large number of 2.5 owners over there and they might well be able to help..
I can't as I only do petrol these days...
What makes you believe the MAP sensor is into trouble?
Lighty
x 35
Re: map sensor
Unread post by Lighty »
I can confirm that Jon's car does have a MAP, as I diagnosed it, and told him to post on here, as I didnt know where to get one from.
The MAP has a large alloy body and the pipe is bolted on via a banjo fixing. It is the biggest sensor I have seen :D
Hopefully some on ecan help, as this car badly needs it to correct a running issue.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 1488
Re: map sensor
If it's the EEC95 engine, then it's still available from Citroen (1920 3L) - £185 though! Alternatively looks like Amazon or e-bay.
The earlier one (1920T7) is NFP from Citroen, but appears to be shared with BMW - This mob look to able to supply one: http://bmwfans.info/parts/catalog/13622244674/
