After exiting the roundabout I pulled over and turned the engine off, waited a few minutes and started the engine and engaged Drive still no traction. I persevered and once I reached 55 kmh the gearbox engaged 3rd gear with normal acceleration at 74 kmh it changed into overdrive still with normal acceleration, I was able to kick-down into 3rd and back to overdrive as normal
At no time did I have Sport/Snow flashing and reverse gear works as normal. I took the car to the local Peugeot workshop and they could not find any fault codes, they advise replacing the gearbox , cost about $ 4,800 + $ 1,000 to install, as the car is valued at $3,000 that option not going to happen.
I Have read in these forums about "the valve block and specifically the Brake Band F3 that engages 1st and 2nd gear via electrovalves controlling the hydraulic pressure to servos and valves.
Can anyone tell me how to replace the electrovalves or how I can obtain the full schematic drawings of the AL4 gearbox.
The Fixer
