2004 berlingo delphi pump
spud6937
Unread post by spud6937 »
hello could any body point me in the right direction ,i have a serious leak on my pump timing belt end, i have had pump removed and hope to fit a a good replacement , the serial number is r8448b 391c i can locate many r8448b pumps, but not with 391c does any body know the difference with these last digits and what the b& c may indicate, its off my work van and im in a bit of a pickle would really appricate any help many thaks
x 94
Re: 2004 berlingo delphi pump
Unread post by citronut »
hi and welcome
why dont you just fit a new pulley end seal to your existing pump, this could have been done in situe
if you send me the last 8 digits of your chassis/VIN No. i will get you the OE price and part No. for the seal
Regards, malcolm.
spud6937
hello ,and many thanks for your welcome and reply , although always had citroen and renault vans not really clued up, when turning shaft it seems to be making a noise ,is there a bearing there also that can be changed and would you know where i could get these
spud6937
hello malcolm , last eight
vin 94134519,many thanks for your help regards MIKE
x 1056
Unread post by wheeler »
Obvously without hearing the noise i can say for definite but all the DW8 pumps I have had off make a loose clicking noise when turning the pump by hand, the first time i heard that noise thought something was gone inside the pump, a brand new one straight out the box makes the same noise. Was the pump making a noise before you removed it ?
Also have you thought about the immobiliser issue if using a second hand pump ? you will need to strip the security armour off both pumps & fit your coded stop solenoid or get a plain solenoid for it.
x 94
here is price and part No. for the seal and dust cover
0000192720 DUST COVER KIT 6.25 GBP 7.50 GBP 7.50 GBP
no bearing listed separately
also pm sent with full characteristics list of what your car left the factory wearing
Regards, malcolm.
spud6937
many thanks for much welcomed help ,malcolm youre a diamond mate ,would you be able to tell where to get or order the parts regards
x 94
the part No. and price are from the main dealer
Regards, malcolm.
