C5 V6 Timing Belt Conundrum
DHallworth
x 167
Unread post by DHallworth »
Started with the timing belt job on the C5 today. Everything pinned nicely, all went in ok.
Followed the process to get the old belt off, everything seemed to be going nice and smoothly to this point.
The instructions state to back the 4 bolts on each camshaft pulley off 1/4 a turn and turn them all fully clockwise. The inlet camshaft on the back bank, the one with the VVT gubbins on the end of it appears to be seized. I cannot get it to rotate at all. Have tried gentle persuasion with a plastic hammer to no avail.
Anybody got any suggestions?
I've also noticed that all of the pins I've got locking the cams have gone as tight as gawd knows what after taking the belt off. I don't remember the XM ones doing that with I changed the belt on that though :?
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8353
Re: C5 V6 Timing Belt Conundrum
Can't help with the VVT bits David but..
DHallworth wrote: I've also noticed that all of the pins I've got locking the cams have gone as tight as gawd knows what after taking the belt off. I don't remember the XM ones doing that with I changed the belt on that though :?
Yep, that happens and it's because the cams move a bit due to partially open valves pushing on the cam lobes and rotating it a bit. Nothing to worry about, just gently rotate the cam in question a little to be able to pull the pins out...
You know the trick of removing the valley roller to enable the new belt to be fitted more easily? Get the belt on and then refit the valley roller afterward...
It's a good idea to recheck the timing after a few rotations of the engine. You may find it's a tad out and needs a slight tweak on the verniers...
Ben82
x 7
Unread post by Ben82 »
David,
Sorry if I'm completely off base here: from what I can see in the document it's that they turn freely, not fully. I only really noticed because, when I was looking around to see if I could find someone with a similar issue, which I couldn't, but I found a video (how's your french?) of the cambelt being changed on (ES9J4 though), and I believe, at 6:20-6:30, is showing what it means from the document:
" onclick="window.open(this.href);return false;
BTW: did you need to remove the LDS cylinder or did you get away with just the coolant one?
Hope this helps
Ben
2004 Citroen C5 3L V6 Auto
DHallworth
x 167
Got away with just the coolant bottle Ben. It's been fiddly but not to bad a job to get down to here.
The vernier adjuster type thing on my rear bank inlet cam is solid, it won't rotate at all with the 4 little bolts undone whereas the front one easily rocks back and forth for the length of the slot in the pulley.
Anybody know how to remove the sprocket from the camshaft? I still can't get my SEDRE discs to work unfortunately.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8353
Yes, counterhold the cam hub and undo the centre bolt David. Be aware it is done up biblically tight!
DHallworth
x 167
That's on a normal pulley Jim, unfortunately this is the one with the VVT stuff hanging off the end of it :(
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8353
Ahh sorry David... Sounds like the VVT has seized.. Be interesting to see why...
x 1485
On service.citroen looks like there is plug in the centre of the variator (it says hex headed, not clear if it is screwed in or not), then under that is an 'E' headed bolt screwed into the camshaft.
PS be careful with it - it's obviously made of unobtanium with a few hen's teeth rolled in, as Citroen want £480 for a new one :shock: #-o
Ben82
x 7
Hi David,
Will PM you with the camshaft removal document (and the dismantling one)... unfortunately, it's very light on information about removing the relevant bits, so not sure how much of a help they'd be.
Ben
DHallworth
x 167
Thanks for your help guys.
Have managed to get the pulley moving. A careful squirt of WD40 round it, a softheaded hammer and a piece of wood to protect the pulley have it moving just as well as any of the others now.
Panic over!
Hopefully today I can get the belt back on and sorted. Just annoying that one of the coolant pipes I need have gone on back order from Citroen :(
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
x 167
The belts on, the tension is set, all the pins are coming in and out of the cams without issue now after many rotations of the engine.
Just got to put it all back together now.
Was hoping the top hose I had on order would of been in stock today so I can give it a run but no such luck :(
Davud,
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Ben82
x 7
Nice one David =D> =D> =D>
How long did it take in total, without the Forum Breaks? :lol:
DHallworth
x 167
Ben,
Without breaks I don't really know. I've put all the covers back on, mount is back on, just need to fit the new radiator to it after dinner and see if it'll start! **fingers crossed!!**
A pal of mine asked me when he visited today what it would of cost at the dealer... I didn't really know so I phoned Glasgow Citroen. They said they'd supply and fit a timing belt including tensioner for £345 inc VAT!!!! :shock: :shock:
If I'd of known that I'd of sent it in there!
I've got an email with the prices in it so if anybody wants to book a V6 in for changing let me know and I'll forward you the quote!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Ben82
x 7
That would be citroens fixed price service in the uk. Bet they hate people who come in with V6s for it! It would be interesting to know whether they honour it for foreign cars as it would have been slightly cheaper for me to drive to the uk and back with getting it done whilst in the uk.
Knowing what I know now, I'll most likely tackle it myself next time. :)
BTW what did you use to support the engine whilst the mount was removed?
DHallworth
x 167
Well, the belts done and I had the car running for 30 seconds and it was sweet as a nut.
Didn't want to run it any longer as there's no coolant in it.
We've got a crane that runs over the 4 post ramp in the workshop that I used this time after taking the bonnet off. Other times I've used a jack with a piece of wood on it under the sump and I've also used a Clarke engine crane before as well.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
