if/when you require fitting seal kIts to the front calipers this company sourced the kits eventually for Chris Salters Visa ( Florance ),
http://www.biggred.co.uk/index.php" onclick="window.open(this.href);return false;
very very good bunch they even gave me a call back after 6pm one day
the story on tracing the kits down is over on the Visa forum which you may have seen already,
most companies said they can supply the kits but then call back saying they are on back order, and dont know when they would be in,
the problem being these are citroen only calipers, not Bendix, Girling , or Teves
also Richard
there is someone on the Visa forum just had his crashed Visa repaired using bits from a de/cap donor car,
maybe there is some usfull body section can be removed to fill the gaps in your puzzle,
if the remains are still around that is
'Recommissioning' the Visa
- x 94
Re: 'Recommissioning' the Visa
Regards, malcolm.
- x 1489
Metal has been cut
There is now a large hole in the drivers floor where there used to be a series of smallish holes. Started making a repair plate, surprised I was able to make a half decent job of the rib with a couple of pieces of wood and the vice!
charentejohn
Not directly related to your current work but still a few in France http://www.leboncoin.fr/voitures/offres ... ecouvrable" onclick="window.open(this.href);return false; Also search for decapotable or cabriolet.
Such as the one for 800 Euro seems good for parts ? Body panels should be good. Cars aren't especially cheap here but there are at least some for sale for spares for most old models, just because they are local here.
Splash out 1500 Euros for this low mileage one http://www.leboncoin.fr/voitures/447935244.htm?ca=20_s" onclick="window.open(this.href);return false; called a 'voiture papi' here. Basically grandad's car being sold due to a death in the family, under 50k miles.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
harryp
- x 73
Richard, so now I too know about the reference "welding the decap". Fascinating. Very envious of your vintage Velo! I had a very secondhand MSS in the early 60's. Pressed chaincase could not be made tight and used to leak oil everywhere. Saw some at a display a few years ago by a Velo Club, all with a drip tray underneath! They seemed a right miserable bunch when I commented on same, not at all like the biking fraternity I remember, lol!! Any way, thanks for all your help.
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 94
Richard
did you sort the door sill yet,
as someone over on the BX forum put a link to a body panel company who list sills for the BX, at £25 quid each,
i cant find the link at the mo but i bought a pisssscasoooo sill from them it looks very good,
i just did a gooooogly search and found this company who list Visa sills
http://www.autopanels-castleford.co.uk/ ... %20Van.htm" onclick="window.open(this.href);return false;
might be worth inquiring
Regards, malcolm.
- x 1489
Things roll on slowly here
No 1 son is getting old enough to start getting involved now, so we did some work on it today. Investigation of the OS rear door shut which looked too sound to be true, turned out to be so, and totally full of filler - and quite a few other holes once it was cleaned out. Nothing I wasn't expecting
basically nothing left of the lower sill, upper sill, closing panel and upwards, and several holes in the inner rear wing. The bottom of the rear wing (inner and outer) is solid filler too
vborovic
- Locked user account
- x 40
Good for you that this topic is not in the selling/buying section, since it would've been erased eons ago ...
- x 5672
Not so Vanja. It is only when it starts to become unpleasant that posts or threads are removed. A very rare occurrence.
vborovic
- x 40
You sure? I thought threads not updated for 200 days are automatically removed ... lost 2 topics this way, asked Richard, had to create new ones from scratch (not a problem really)
- x 5672
90 days for "For Sale & Wanted" if the thread hasn't been added to in that time. All others remain in all eternity but get archived periodically.
Only duplicate threads are either merged or one deleted, depending on responses.
- x 94
myglaren wrote:Not so Vanja. It is only when it starts to become unpleasant that posts or threads are removed. A very rare occurrence.
i would say Richards findings were far from pleasant StevieRichardW wrote: Investigation of the OS rear door shut which looked too sound to be true, turned out to be so, and totally full of filler - and quite a few other holes once it was cleaned out. Nothing I wasn't expectingbasically nothing left of the lower sill, upper sill, closing panel and upwards, and several holes in the inner rear wing. The bottom of the rear wing (inner and outer) is solid filler too
sound like there is nout left of this car above the floor pans
Richard im sure i had a Visa door sill in the dark corners of my shed gathering surface!!! rust
Regards, malcolm.
