well I have noticed with mine the problem only exists when engine is cold.. which is most journeys I do.. once warm, car is ok.. light remains on sometimes after restarting, sometimes it's off but comes back on soon after..
anyway.. will have a good look around it at weekend.. after doing a handbrake cable and guide.. will also try to read codes as best as I can..
but the cold thing.. points at EGR for starters really..
03 C5 2ltr hdi be sluggish going uphill...could this be the
jgra1
- (Donor 2021)
- x 36
stu9
- x 5
Re: Should an 03 C5 2ltr hdi be sluggish going uphill
Gibbo and others
I put a new ic today
Still the same....ie cuts on on boost but starts a few mins later
Could a blocked or duff egr cause this
stu9
- x 5
Can anyone say if an egr can cause this.....or if not then what, cheers
Citroenmad
- x 110
Its perfectly fine to clean a MAF sensor with just spray solvent. Ive done this many times with all our 2.0HDi 110s and never had a resulting problem, quite the opposite which is why it is of benefit. However you must never touch the elements with anything physically, but a solvent spray is fine.
Our current 110 C5 had a similar leak to yours. Once I replaced the intercooler for a new one the car has never been any further trouble. Doesnt use any oil and doesnt smoke either. That was about 20k miles ago.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
stu9
- x 5
Ok, but this doesnt help with what I'm asking
stu9
- x 5
Re: 03 C5 2ltr hdi be sluggish going uphill...could this be
Saw this on another forum....he had a P0230 code..
If this is the problem, where do I find this..
Replaced the solenoid on the top of the pump (the one thats held in by 3 small Torx screws) but to no avail, then removed and replaced the rubber 'O' Ring (Very small GREEN one) and found a small tear/slight score in the old one, this fixed the bloody fault!!!
- x 94
i havent followed the hole of this thread but has anyone suggested you get the car hooked up to a LEXIA to see what that shows up
Regards, malcolm.
- x 94
i havent had much if any driving experience of C5's but most older citroens dont like driving at 30mph in 4th gear, and dont like 4th till nearer 40mph,
so if the C5 is like the older citroens this is nornal
Regards, malcolm.
stu9
- x 5
I know....someone's hopefully coming today to do it
I know you say they dont like being at 30 in 4th, and not happy till nearer 40 in the gear...not much use that if you're suppose to sit in 3rd when in town, it's going to use more fuel like that, after all, the idea of having a diesel is the mpg, grunt/torque
oneday
c5 is more than happy in 4th at 30
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
stu9
- x 5
I know that's what i though
taffy
After reading this I would suggest buyin a mechanical boost guage off ebay ( tenner) and run it accross The turbo solinoid to watch how it behaves during driving conditions...its helped me cure my lock of boost syptoms...was a split in pipe I didn't notice and was getting vac of 10-11 psi now upto 20 psi with air leak fixed so before it wasn't closeing The wastegate properly at low revs and jus blew out all The boost untill 3000 rpm
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
My cars happy at 90 in 4th
stu9
- x 5
I thought about that, but as I've put it in the garage till it sells, I probably won't.....but after our discussion on the other post, you're making me think about using it again and trying hard to get used to it. The thing annoying me now though is now that you've mentioned about this sport button that stiffens things up (that I don't have being the LX model)...I either try and used to a driving boat or selltaffy wrote:After reading this I would suggest buyin a mechanical boost guage off ebay ( tenner) and run it accross The turbo solinoid to watch how it behaves during driving conditions...its helped me cure my lock of boost syptoms...was a split in pipe I didn't notice and was getting vac of 10-11 psi now upto 20 psi with air leak fixed so before it wasn't closeing The wastegate properly at low revs and jus blew out all The boost untill 3000 rpm
taffy
All I can say I drive a standarf car dowm a road u know well with bumps etc then take The c5 down it....then u will see The difference....you might not feel The road as much but you should have comfort like a bently...and a bently only has The hydrolic on The rear axlestu9 wrote:I thought about that, but as I've put it in the garage till it sells, I probably won't.....but after our discussion on the other post, you're making me think about using it again and trying hard to get used to it. The thing annoying me now though is now that you've mentioned about this sport button that stiffens things up (that I don't have being the LX model)...I either try and used to a driving boat or selltaffy wrote:After reading this I would suggest buyin a mechanical boost guage off ebay ( tenner) and run it accross The turbo solinoid to watch how it behaves during driving conditions...its helped me cure my lock of boost syptoms...was a split in pipe I didn't notice and was getting vac of 10-11 psi now upto 20 psi with air leak fixed so before it wasn't closeing The wastegate properly at low revs and jus blew out all The boost untill 3000 rpm
