Every time i get out the car keep getting small electric shock off the door???
All the electrics in car are fine??
Any ideas?
C5 mk1 estate Electric shocks
ej2095
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
taffy
Re: C5 mk1 estate Electric shocks
Yea me too lol wat The hell is it!?......
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
- x 5668
Has to be static.
Synthetic fibre clothing is a common cause.
taffy
Lol I think ur rite! Haha!
- x 1240
It happens when the air is very dry, when its damp the charge leaks away. Its happening to me when I shuffle along the floor to put some fuel on the stove, you can hear the 'crack' as I go to get hold of the door - or touch the cat
ej2095
lol very annoying.... time for a earth stap lol
ej2095
Why did i have the image of that dog that drags its ass along the floor.... corner to corner for maximum wipePeter.N. wrote:It happens when the air is very dry, when its damp the charge leaks away. Its happening to me when I shuffle along the floor to put some fuel on the stove, you can hear the 'crack' as I go to get hold of the door - or touch the cat![]()
- x 694
Used to happen to me all the time in hot dry weather in NZ... ZAP...
My solution was simple, after opening the door but before swinging my feet out I would grasp the metal of the top corner of the door and keep my hand in contact with the metal as I climbed out and stood up, not letting go until I was standing. This way no charge can develop between your body and the door to zap you when you reach to close the door...
mooseshaver
Happens to me in every car and out of habit now I touch door before my feet land.
You used to be able to buy things that dangled down under the car and touched the ground when stationary. Used to always see them on Ford Escorts as a child (80s)
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
ej2095
must be that time of year getting shocked again lol
rabenson
Could be your choice of footwear - the car and you build up a static charge while you are driving then when you get out, if your shoe soles are conductive the charge on your body gets grounded when you step out so you are now at a different potential to the car. so now when you touch the car, its charge gets grounded through you - hence the shock. It used to happen to me every time I wore a particular pair of trainers but was fine when wearing other shoes, which presumably had higher electrical resistance soles.
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
qprdude
- x 14
Plenty anti-static straps on Ebay for a few quid. Cheaper than buying separate clothing and footwear just to drive your car.
Rick.
2013 Citroen DS 5 D/Sport
- x 694
An anti-static strap from the car to the ground will only stop a static charge building up between the car body and the ground - it won't stop one building up between you and the car due to friction between your clothes/shoes and the seat/carpet. Most of the static charge is generated by rubbing your pants across the seat.
I used to have this problem a lot on my previous Xantia with cloth seats. A workaround is to modify the way you get out of the car - after you open the door and start to swing your legs around to get out, grasp the corner of the door on the metal with one hand BEFORE your feet touch the ground and KEEP that hand grasping the metal frame of the door during the entire time you are climbing out until you are standing with two feet on the ground, then you can let go.
Follow this procedure and you will never be shocked leaving the car. After a while this technique became a force of habit for me because without it I was getting shocked nearly every dry summer day in NZ.
qprdude
- x 14
Not sure I understand why the static strap is of any use in that case. What is it's purpose, if not to earth the static electricity from the car so that there isn't any to transfer to yourself? I've never had this problem in any car. With or without cloth seats, and wearing everything from nylon shorts to a kilt ( No frocks)
. The method of getting out of the car by grasping the door frame might be OK for you just now, but wait until you're a pensioner and it's a matter of getting out by the easiest means without falling on your arse, never mind grabbing door frames with your feet hovering in mid air
. There just has to be a simpler way.
Rick.
- x 1240
The static is built up between you and the car as you slide over the seat, so earthing the car doesn't help a lot. The determining factor as to whether you generate static or not depends on the humidity, if the air/your car/your clothing is very dry, that's when it happens.
