Hi Mike,
It is a hex (Allen) and it's 6mm..
Can be quite tight too... You nee a good hex bit on the end of a short breaker bar...
Rear ram bush
- x 8406
Re: Rear ram bush
- x 8406
Re: Rear ram bush
It's quite big in Allen head terms Mike. the bolt itself is quite meaty. I'm pretty certain it's 6mm. Same size as a 4HP20 drain plug...superloopy wrote:Cheers Jim, 6mm sounds quite small?
