C5 left wiper broken
hdi_man
Unread post by hdi_man »
another problem with my 2008 C5 !!!!...the left wiper suddenly just stopped working today, the drivers side one also now only goes at 1 speed. I can see the other wiper jumping as if it wants to move but nothing. broken motor perhaps ?? :cry:
SaabC5
Re: C5 left wiper broken
Unread post by SaabC5 »
Normally one motor drives both arms so suspect broken spindle or arm has come off the splines of the spindle.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
hdi_man
interesting. maybe its electronic fault as the good wiper is now only moving at slow speed. nothing like constant problems to keep you on your toes...cheers Citroen..... :roll:
x 1472
Mk 3 C5 has individual motors for each arm, and (almost certainly) an ECU to control them. If you put it on a Lexia it may give a fault on the wiper motor (s) or ECUs. Mandrake is near Glasgow and has got a Lexia.
New motors are a mere £250. Each :twisted: :shock:
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
It happened recently with daughters Xsara. One of the ball joints had separated. Difficult repair so sourced a replacement motor and drive from ebay. Cost about £22.
Image[/URL]
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
SaabC5
RichardW wrote:Mk 3 C5 has individual motors for each arm, and (almost certainly) an ECU to control them. If you put it on a Lexia it may give a fault on the wiper motor (s) or ECUs. Mandrake is near Glasgow and has got a Lexia.
Two motors! Now thats progress for you........not! :evil:
JohnD
(Donor 2022)
x 72
RichardW wrote:Mk 3 C5 has individual motors for each arm, and an ECU to control them. :
Almost bound to be otherwise they could quickly get out of sync. That would be fun :P
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
BrianM
Unread post by BrianM »
Failed on mine too when still under warranty (what hadn't !).
Motor replaced. It shows up as a fault when on a diagbox session.
Wonder if water ingress could be a factor from a windscreen replacement ?
Brian
09 C5 Exclusive
hdi_man
wiper motor failed. local garage took it apart and tried to repair it but no good.
citroen want £215+VAT for a new one so now trying to source a salvage part.
seems as if its just part after part that needs replaced now, at least something every 2 months. poor build quality :evil:
hdi_man
water ingress is a possibility, there was a white residue on the motor (salt ?).
when I get new wiper motor and replace it I will need to glue the windscreen seal back down, what kind of sealant is used for this ??
Jabo
Unread post by Jabo »
hdi_man wrote:seems as if its just part after part that needs replaced now, at least something every 2 months. poor build quality :evil:
My 2001 model is the same :(
2001 Citroen C5 SX 2.0 petrol - Misty Lilac
0-60 MPH Calculator - Android app - https://market.android.com/details?id=c ... zero60full" onclick="window.open(this.href);return false;
Weight Transfer Calculator - Android app - https://market.android.com/details?id=c ... ansfercalc" onclick="window.open(this.href);return false;
hdi_man
yes but mines 58 plate !! this much should never have gone wrong with a car so young
coastline taxis
Unread post by coastline taxis »
http://www.dft.gov.uk/vosa/repository/Bulletin%2073.pdf" onclick="window.open(this.href);return false;
Go to page 10 there was a recall for the wiper motors on your c5. print it of and go to dealers
hdi_man
recall is interesting but it states drivers side. its the passenger side thats failed on mine. I sourced a replacement for £65 and hopefully that will sort it !...
x 694
Unread post by Mandrake »
If the recall advisory was originally written for the European (LHD) market drivers side could indeed mean the left hand side of the car, but I guess its a moot point now that you've ordered one.
