xantia 110 hdi clutch
x 1485
Re: xantia 110 hdi clutch
Don't think the washers are required - should be easy enough with the gearbox out of the way - access is pretty limited normally, but if you wind the steering onto full LH lock with the box out, the joint shold be right there exposed at the back of the engine bay :lol:
I doubt that taking the box out is normally a good way to do this job though :mrgreen:
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
They list two because there's two sizes fitted.. the smaller threaded one is fitted to HDi 90 models and the larger i think m16 is fitted to hdi 110 models. ..
A very sad...
1994 XM 2.1 d auto
taffy
Unread post by taffy »
citroenxm wrote:They list two because there's two sizes fitted.. the smaller threaded one is fitted to HDi 90 models and the larger i think m16 is fitted to hdi 110 models. ..
oh christ i hope ive got the right one!
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
right im readt to go my driveshaft seals jus come through letter box!!
but its raining.....but ive got no choice
tarpaulin will have to be sourced lmao!!
taffy
well I started yesterday midday and by last night had box off and clutch...this morning I'm doin wishbones and antiroll bushs....all I can say its a job and a half! And The box is mega heavy...I can't even lift it into place....broke one driveshaft intermediate was in The bearing housing proper had to beat it out and its distorted now...thank god that's only damage I've done so far...clutch was interestin...was thinking would have to skim flywheel but was ok however The pessure plate was bad and even springs had started rubbin...oh well bk to it...
x 94
Unread post by citronut »
taffy wrote:well I started yesterday midday and by last night had box off and clutch...this morning I'm doin wishbones and antiroll bushs....all I can say its a job and a half! And The box is mega heavy...I can't even lift it into place....broke one driveshaft intermediate was in The bearing housing proper had to beat it out and its distorted now...thank god that's only damage I've done so far...clutch was interestin...was thinking would have to skim flywheel but was ok however The pessure plate was bad and even springs had started rubbin...oh well bk to it...
how dod you manage to detroy the intermediate bearing, as the bit you hit is a spacer collar which is against the bearing,
Regards, malcolm.
taffy
Well got box on clutch working jus need to sorce another drive shaft...wishbones were knackered not a fun job a
taffy
And it was The driveshaft little bearing they came out everywhere
x 8365
I believe that with a little ingenuity that bearing can be replaced Taffy.. It's a pretty standard sort and can be sourced (I believe) from generic bearing suppliers at an economical cost.
Getting the old one off is not a problem as it almost is and all you'll beed to do is fabricate a long hollow mandrel (a piece of scaffold tube perhaps) to drive the new one home..
If you know the dimensions, shielding and ball-count then this mob should be able to supply...
x 1485
It's still available from Citroen - but does cost £21 :evil: says its 35 x 62 x 16 - I imagine it's a metal sealed bearing. Unfortunately seems to be a non std size (there's a surprise :lol: ) - simply bearings list 14 and 18mm but not 16mm. I'd have thought a 14 would do it - take the slack up in the retaining bolts. A more reasonable £5 or so :wink:
taffy
Its The small neadles I've lost inside The inner cv joint as I was so stubbon to remove intermediate it poped off and went everywhere...I am gona do The shaft bearing but at The mo I'm under pressure to get bk to work so I gota get car bk on road asap....I've had a good look inside engine bay now and I'm appauled how citroen pipe theses cars it jus looks so messy! I've done wishbones drop links gota do inner tie but couldn get rubberoff also gota do ball joints again...quick question on rear engine mount is it better to take The bracket off? Thanks for ur support gents
x 8365
Ahh sorry Taffy, I mis-read what bearing you were speaking of...
I guess you mean the tripod ones inside the CV joint..
If you can find all of the spilt needles you can rebuild it...
x 94
if you send me the last 8 digits of your chassis/VIN No., i will check which shaft fits your car and do an all families search to check which other models use the same shaft,
then you can try and get one from the breakers,
all being you cant find all the needle rollers
Regards, malcolm.
taffy
well in The end I found another driveshaft of a 90 and used The neadle bearings from that and went together well.....clutch feels good but engine mounts lettin it down now...
taffy
Oh and another thing...The ride height of The car is really high will it settle in time or have I done something lol
