I have recently replaced my mk2 Xantia with this newish Mk2 2.2Hdi 6speed autobox C5 model mid 2006, with only 40000 on the clock. After few months of use I now discovered the tailgate lock will not open despite pressing the switch. All you hear is the motor turning and timing out.
I had to fold down the rear seats to get at the lock and open it through the hole provided for emergencies. Has any one else come across this before and how expensive a lock is this likely to be. Can some one give me a part number for this electronic lock assembly please
I would like to change this lock but can not even figure out how to remove the trims,
is it just brute force and pull it off or are there any hidden screws and special sequence to follow.
I hope to find a suitable service manual on the fleabay. Would the BOL help for this job.
Any advice will be most appreciated
Masood
C5 2.2HDi with a 56 number plate, boot lock fault solved
masood_ilyas
- x 1498
Re: C5 2.2HDi with a 56 number plate, tailgate lock failure
Masood - it is an estate or hatchback?
masood_ilyas
It is a hatchback Richard.
- x 1498
Masood
There are 4 plastic pins in the bottom, 2 screws in the internal handles and 6 plastic pins across the top by the look of it. PM me your e-mail and I'll send you the drawing from service.citroen.
The lock looks like a one piece unit, no connection rods or similar, and is not that bad really:
Part Number Description Quantity Price excl. VAT Price incl. VAT
0000871986 TAILGATE LOCK 26.75 GBP 32.10 GBP
Might be possible to dismantle and see what's up with it?
One other thought - check in the handbook that it is not possible to diasble the central locking from the boot somehow - I recall you could do this on Xantia hatches......
masood_ilyas
Re: C5 2.2HDi with a 56 number plate, boot lock fault solved
Thank you Richard for the part number and drawing showing location of pins securing the trim.
It was warm and sunny over the weekend allowing me to dig in a bit and investigate the fault.
After removing the trim and undoing the screws
I was able to slide the lock out from behind
remove arrowed screws to reveal the inner construction of the assembly
and the reason for the boot lock failure, a few missing teeth. I did carry some Belgian chocolate in the back, but I am sure they did not damage these teeths.
It is a shame I can not buy the 10p worth of plastic gear as the stealer will only sell complete unit at £32. Also a sad state of affairs with new cars, bits falling and breaking after only 5 years of motoring, compared with a Xantia standing on the driveway still going strong after 15Years, with all bits intact including the boot lock.
Thanks you all for your help.
Masood
.remove arrowed screws to reveal the inner construction of the assembly
Masood
