front discs
froggy
- (Donor 2026)
- x 4
front discs
Hi, my 1997 Xantia TD, I have just noticed quite a large lip on the edge of the front discs. Iam about to change them, Iam guessing the two torx screws hold the disc on? are they generally easy to free? thanks in advance Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
addo
- Sara Watson's Stalker
- x 95
- x 7165
Re: front discs
Terry
The demon rust often stimulates a bit of creative thought to get discs off.
rusted on discs
This includes my own hacksaw and cold chisel method when all else fails.
Hope yours just follows paragraph 9 section 10.6 of the Haynes Manual
" Unscrew the two brake disc securing screws and withdraw the disc from the hub"
regards
rusted on discs
regards
Xaccers
- x 188
Re: front discs
I've had to drill the heads off and once the discs were off unscrew the studs with grips.
Make sure you get the right size replacement discs as many motofactors have the smaller size listed against Jenny and she's R reg.
If you need the smaller discs give me a shout and you can have my extras for a few beer tokens.
DIY sphere tool
DIY sphere tool
- x 3296
Re: front discs
Once you have removed the discs, clean up the surfaces of the hubs, and apply a liberal coating of copper slip grease just before you fit the new discs, to help prevent them rusting on in the future. I did when I replaced them on Gracie.
froggy
- (Donor 2026)
- x 4
Re: front discs
As mine is a series1, will it have smaller discs? I assumed ( stupidly), that there was only one size of disc. I am guessing I will have to measure them? unless there is another option, thanks for all your help, cheers Terry.
Terry
dnsey
- x 19
Re: front discs
Once the retaining screws are out, a three-legged puller applied to the disc and tightened moderately, then tapped with a hammer has always worked for me.
Xaccers
- x 188
Re: front discs
Never assume!froggy wrote:As mine is a series1, will it have smaller discs? I assumed ( stupidly), that there was only one size of disc. I am guessing I will have to measure them? unless there is another option, thanks for all your help, cheers Terry.
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Re: front discs
Hi Xac, mine are the small discs too. how much do you want for them? cheers Terry.
Terry
Xaccers
- x 188
Re: front discs
Let me measure them up tomorrow when I get back from work just to confirm the diameter 266mm (I take it you measured yours rather than going by an online list?).
How's £25 for a pair sound?
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Re: front discs
very good, I will wait for you to confirm tomorrow, cheers Terry.
Terry
Xaccers
- x 188
Re: front discs
Hi Terry, sorry for the late reply, the discs are 266mm
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Re: front discs
Thanks Xac, how do you want me to pay? postage? cheers Terry.
Terry
Xaccers
- x 188
Re: front discs
I'll have to get them weighed and find the cheapest way of getting them to you.
Where abouts are you?
DIY sphere tool
DIY sphere tool
froggy
- (Donor 2026)
- x 4
Re: front discs
Dymock, Glos, Cheers.
Terry
