Any advice please ?
Hipster
Any advice please ?
Unread post by Hipster »
I was driving my Citroen xantia 2.0 turbo diesel on the M25 and it just died. I don't recall a bang or smoke, it just lost all power. It turns over but will not start. A massive pool of oil formed underneath it so something has gone. It's only done 180 k which is low for a diesel. Don't know what to do.
Rob
x 8431
Re: Any advice please ?
Rob, something appears to have let go in a big way if there's a pool of oil underneath...
Can you identify the source of the oil?
Hipster
you can't see where the oil is from. It's obviously fired out und pressure and has coated everything then dripped off into a pool underneath afterwards.
x 8431
Rob, does the engine sound normal when it's turning over on the starter or does it sound a bit 'chuffy' and possibly turning over rather faster than normal...
One check you must do is the cambelt. Slip off the belt covers and turn the engine over and check the cam and injection pump sprockets turn as expected. If they do, check the timing by pinning the cam and crank as you may have stripped teeth from the belt and as a result the timing is now very awry...
If the belt has broken or stripped teeth it's not often fatal as the HDi engine (which I make a big assumption your engine is) breaks rockers rather than bends valves when a cambelt lets go.
The earlier 1.9TD usually suffers a broken cam and broken cam caps which effectively writes off the head. The 2.1TD is the same as the HDi in that rockers break. Rockers are easy enough to replace...
No diesel if it's suffered a belt slip will start as timing is very critical...
So, check the belt and timing Rob and then get back to us...
It'll also help if you can positively identify the engine for us too...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
CitroJim wrote: The 2.1TD is the same as the HDi in that rockers break. Rockers are easy enough to replace...
The HDi is actually the same as the 2.1 TD :wink: As the HDi replaced the 2.1 originally, so they followed the 2.1 idea of rocker breakage rather then outright engine destroyment... :-D :-D :-D
Could the sump plug possibly of dropped out of the plug threads have been stripped from over tightenging??
of course untill we know what engine it is, it will be harder to tell, but I think any engine thats lost oil while in motion wont be any good afterwards sadly.
A very sad...
1994 XM 2.1 d auto
Hipster
It is an hdi turbo diesel. Sump plug not the problem. Mechanic I know is thinking it could be from turbo feed ???
Thing is I though these diesel engines went on for 300 - 400 K
Rob
Hipster
Cam belt has no gone Jim
It is an hdi turbo diesel. Mechanic I know is thinking it could be from turbo feed ???
Rob
x 8431
Good to hear the cambelt is OK Rob :-D
Could well be the turbo has let go through loss of lubrication but it should not cause the engine not to start even though it'll run badly unless the turbo has broken up and filled the cylinders with swarf and debris and caused a massive loss of compression...
More investigation needed Rob...
citroenxm
Fallen Hero
x 70
It sounds like its shear bad luck.. :(
These 8v units are VERY Strong... I broke a 288k Xantia, which had a good block and turbo...
My Own HDI Exclusive has just turned 240k and is sound as a nut!
A very sad...
1994 XM 2.1 d auto
