HDI Xantia aux belt and tensioner and pulley wheel
charentejohn
Re: HDI Xantia aux belt and tensioner and pulley wheel
Good point, I will double check before trying. I want to give the car a run out first just to make sure all is well, then I can mess it up again.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
KennyW
- x 163
Pulley diagram below
When I did my belt I used long 15mm ring spanner to move the tensioner and the small hole is to lock with a pin to hold in place whilst fitting
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 94
Kenny
i think the bolt John is referring to it for the manual tentioner
Regards, malcolm.
charentejohn
Yes Kenny it is the manual one at the bottom of the belt system.
Then again your photo shows the oily thumbprints of experience in this area
