306- air
froggy
(Donor 2026)
x 4
306- air
Unread post by froggy »
Hi, my wifes 306 (1.4) I need to draw air out of the system on a monthly basis! it runs fine for about a month, then it runs too hot, let the air out of the system and its fine for the month. anybody got ideas why this is happening? many thanks in advance Terry. :(
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1238
Re: 306- air
Unread post by Peter.N. »
The most likely cause is a leaking head gasket.
Welshy_Pete
Re: 306- air
Unread post by Welshy_Pete »
Whats the oil looking like?
Also does it loose water coolant?
froggy
(Donor 2026)
x 4
Re: 306- air
oil looks ok, yep using a little water. just noticed "mayonaise" type substance, on inside oil filler cap. guess that confirms water in engine and head gasket leak? cheers Terry. :cry:
Terry
x 94
Re: 306- air
Unread post by citronut »
at least the 1.4 TU lump head gasket job is very very easy, unless its been severely over heated this can cause the wet liners to drop,
is there signs of oil down the front cam belt end face of the block, below head joint level, as this is the usual sign of head gasket failure on the TU lump
Regards, malcolm.
froggy
(Donor 2026)
x 4
Re: 306- air
yes there is!
Terry
spider
x 77
Re: 306- air
Unread post by spider »
I'd agree air is possibly headgasket, now you've confirmed there's oil on the 'shelf' (as I call it) its about confirmed.
Easy to do though as Malcolm has said, usual care to not knock the liners about (1.6 is cast block and does not have this concern, 1.4 and 1.1 do) BOL shows two 'hooks' to rock the head off, the dealer tool is similar actually just to bent rods. To be honest if you don't turn the crank with the head off should be OK though I guess. See BOL for 'clamp' if needed.
I'd recommend the water pump while you are there as you'll have to drain the coolant anyway. The single tensioner roller might be worth changing as they are not expensive.
Andy.
