clutch? clutch?
- x 94
Re: clutch? clutch?
thought i'd post the reply here rather than through a pm
are you looking in pug service box or service citroen, as you say service box
part No. and length
2150 T3
CABLE-CLUTCH
LONG 1578
price and part No.
00002150T3 CABLE-CLUTCH 48.54 GBP 58.25 GBP 58.25 GBP
just enter your VIN No. at the top left in the under were it says FREE SERVICE, click ok then everything it shows will be your specific jalopy
part No. and length
2150 T3
CABLE-CLUTCH
LONG 1578
price and part No.
Regards, malcolm.
Harlequin
- x 24
Re: clutch? clutch?
thank you (again)
yes it service citroen (and your few lines have ofc shown me how to use it properly!)
Harlequin
- x 24
Re: clutch? clutch?
ARGH!
it didnt fit!
seriously its too short !
both ECP and autolec said that was the correct part , but it looks nothing like the old one - apparantly i have an ME gearbox not an ML5 !
sigh so now have to wait for teh right one to be ordered in
it didnt fit!
- x 8353
Re: clutch? clutch?
Nope, you have neither - you have a BE3....Harlequin wrote: apparantly i have an ME gearbox not an ML5 !
Anyway, an ML5 is hydraulic so no clutch cables involved - just gear-change cables which you don't have either...
I note some parts suppliers are terrible for getting muddled these days...
- x 94
Re: clutch? clutch?
thats odd as service citroen only shows the one option with your chassis No.
unless someone has fitted a different box at some point
Regards, malcolm.
Harlequin
- x 24
Re: clutch? clutch?
according to the parts catalogue at autolec theres 3 cables and i have an ME gearbox code (using a 1760mm cable); the ML5 uses a 1578mm cable and the BE3 uses a 1365mm cable ; yet service citroen says its an ML5 as posted above!
- x 8353
Re: clutch? clutch?
We are speaking of a 1.9TD Xantia here aren't we?
- x 94
Re: clutch? clutch?
this is what S/C comes up with regarding your chassis No.
Vehicle family SYNERGIE
AS RPO No 7570
Warranty Start Date 28/08/1997
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY SYNERGIE
SILHOUETTE FAMILY SALOON
TRIM LEVEL LEVEL 2/5
ENGINE TURBO DIESEL XUD9TE
TRANSMISSION BVM5
INTERIOR TRIM TYPE ARMOR VELVET "EJ"
UPHOLSTERY COLOUR "FC"
GEARBOX (CHARACTERISTICS) BVM ML5T
ENGINE (TYPE) XU/XUD
OTHER BADGE TURBO D
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE SX
AS RPO No 7570
General information
PRODUCT TYPE CAR
TRANSMISSION BVM5
OTHER BADGE TURBO D
BADGE SX
Regards, malcolm.
Harlequin
- x 24
Re: clutch? clutch?
i know! but the 1578mm cable for the ML5T doesnt fit , it was simply too short.
the one i wanted (and came off the car) looked like this:
http://www.eurocarparts.com/ecp/c/Citro ... 4b8&000063" onclick="window.open(this.href);return false;
yet the pattern from all teh numbers said it was:
http://www.eurocarparts.com/ecp/c/Citro ... 6ef&000063" onclick="window.open(this.href);return false;
- x 94
Re: clutch? clutch?
no Jim its a Synergie and my next post below your last one shows a snippet from the characteristics using Harlequin's chassis No. in service citroen,CitroJim wrote:We are speaking of a 1.9TD Xantia here aren't we?
this show what citroen say it left the factory with
Regards, malcolm.
- x 94
Re: clutch? clutch?
just looked at a BVM ML5T box on S/C and uts hydraulic not cable,
maybe this wagon has been modded/altered,
although it shows it has a cable with the chassis No.
Regards, malcolm.
Harlequin
- x 24
Re: clutch? clutch?
i`ll happily go crawling - where do i find the geabox part number stamped on the box?
- x 94
Re: clutch? clutch?
have you measured the length of the old inner cable, might pay to measure the outer as well,
also pull the inner out as far as you can from one end and measure the protruding length of inner
Regards, malcolm.
Harlequin
- x 24
Re: clutch? clutch?
it might have stretched but not 20 cm!
got one from autolec in bexhill ( they actually rang and said they had one) snug fit and the adjuster ( once the green lock was removed as the very very last job) is working its way into to proper adjustment
- x 8353
Re: clutch? clutch?
Sorry, I had it that it was a Xantia
Silly me...
But still, as you say malcolm, an ML5T is hydraulic and in no way are they amenable to being cable operated....
Harlequin, can you take some photos of the offending item?
