I agree, it many be next winter that starting problems arising from tight clearances and the odd XUD quirk of having tightest clearances when stone-cold come and bite you.smoker wrote:Think I'd rather tackle it now, especially as summer's here!
XUD Valve Shims
- x 8422
Re: XUD Valve Shims
smoker
Re: XUD Valve Shims
I was thinking, rather than disturbing the whole timing belt end, I could zip tie the belt to the cam sprocket, unbolt the cam sprocket while keeping it tensioned then suspend it for example from the underside of the bonnet using a bunjee chord or similar. Is this a recognised process, or just mad corner cutting?
Separately I'll try to contact a few cylinder head reconditioners to see if they have shims on a sale or return basis.
52 reg Xsara 110 hdi
spider
- x 77
Re: XUD Valve Shims
I'd not bother with that as its so so easy to tension the XUD with its auto tensioner (assuming its not seized but there's ways around it) as you'll have to unbolt the tensioner to get the head off anyway.
Andy.
Oldpug
- x 94
Re: XUD Valve Shims
No !!Just reading that makes me shudder......... One false move and you will have bent valves,a camshaft in four pieces and cracked head caps when you try to start it.
Its a proper job or nothing.If you don't its going to defeat the object of adjusting the clearances in the first place??
- x 8422
Re: XUD Valve Shims
Oh gosh nosmoker wrote:I was thinking, rather than disturbing the whole timing belt end, I could zip tie the belt to the cam sprocket, unbolt the cam sprocket while keeping it tensioned then suspend it for example from the underside of the bonnet using a bunjee chord or similar. Is this a recognised process, or just mad corner cutting?
Northern_Mike
Re: XUD Valve Shims
Yes! Do it! Please post pictures of the results!smoker wrote:I was thinking, rather than disturbing the whole timing belt end, I could zip tie the belt to the cam sprocket, unbolt the cam sprocket while keeping it tensioned then suspend it for example from the underside of the bonnet using a bunjee chord or similar. Is this a recognised process, or just mad corner cutting?
I once changed a timing belt by cutting it in half along its length with a stanley knife, sliding half of it off, sliding the new one half on, and cutting the remainder of the old one off. Wriggled the new one fully onto the sprockets, job done.
That was on a Ford Pinto.
Seriously, You're dealing with something with the potential for engine ruining damage if you get it wrong. Don't risk it..
Oldpug
- x 94
Re: XUD Valve Shims
Consider yourself well and truly chastised smoker.
smoker
- x 8422
Re: XUD Valve Shims
You old bodgerNorthern_Mike wrote: I once changed a timing belt by cutting it in half along its length with a stanley knife, sliding half of it off, sliding the new one half on, and cutting the remainder of the old one off. Wriggled the new one fully onto the sprockets, job done..
I have heard of that being done on an XUD and another variation doing it with the engine running to make slicing the belt easier
Thing is if it goes wrong on a boat anchor (sorry, Pinto) it's a non-interference engine so it just stops. On an XUD it's to all intents and purposes bye bye head..
No need, you asked a fair question and suggested a method and we just pointed out that it could all end in tears... No shame there and exactly what a forum is forsmoker wrote:Hangs head in shame.
