Xantia 2.0i petrol
When I ease off the pedal, revs stay as before and then drop with a jolt. Any ideas what to look for please ? All I have tried so far is spraying a bit of WD40 about.
Jerky Xantia Throttle
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
Xantia 2.0i petrol
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
I have just had a similar problem with my 2.1TD. The revs stay put then will drop with a jolt, or I found that lifitng the pedal would cause the revs to drop. I too tried spraying WD40 around the mechanical bits. Eventually discovered that the carpet was interferring with the pedal operation. Bye the way my wifes Ax had similar problems, and the casue was also carpets interferring with the pedal operation..
Xantia 2.0i petrol
