FCF Contingency Forum ***Please Read***
- x 8333
All,
Due to the main FCF webserver being down due to power issues, you are now viewing the emergency/contingency FCF hosted on a different server.
It is based on the most recent backup from 02:00 this morning.
You can use this forum freely but please be aware thast posts you make may mot be replicated back to the main FCF board when it is made to work again. similarly, some posts made between 02:00 and 08:00 this morning may be lost...
The main FCF servers are unliley to be working before late Monday.
Please be aware too that the emergency/conmtiongency host is not that fast and the forum may run slowly at times..
We thank you for your patience...
spider
- x 77
Re: FCF Contingency Forum
It failed just as I was replying although I did save said reply thankfully as it was a long one.
Andy.
- x 8333
That's good Andyspider wrote:It failed just as I was replying although I did save said reply thankfully as it was a long one.
I was trying to activate a user when it failed...
Post your saved reply as both the FCF and BXC are so busy now this database will be used to restore the main production one when the servers are back up and running next week...
red_dwarfers
- x 58
Re: FCF Contingency Forum ***Please Read***
Thanks for the emergency forum chaps!
Kev
'19 C4 Cactus 130 Flair
- x 8333
It is a pleasure Kev
No way in which we were going to leave all our readers deprived over the weekend. That would just not do...
Anyway, Andy, Steve and I like a quiet life and there's no way we wanted to face an angry mob brandishing boiling LHM and flat spheres banging on our doors because the forum was down...
Still, at least we've proved our contingency measures work and our backups are good...
The only small problem is the FCF database is so big now that it takes several hours to restore to the contingency server...
In fact it can be accurately timed thus: The time it takes to remove the front disc and pads from a Berlingo and go to the factors to get some new ones...
Northern_Mike
You forgot "and guide Northern monkey to remove discs and pads" and "drink copious amounts of tea"....CitroJim wrote: In fact it can be accurately timed thus: The time it takes to remove the front disc and pads from a Berlingo and go to the factors to get some new ones...![]()
Thanks Jim!
- x 8333
Northern_Mike wrote: You forgot "and guide Northern monkey to remove discs and pads" and "drink copious amounts of tea"....![]()
Thanks Jim!
No worries at all Mike, it was a most enjoyable day indeed
I must say, you can drink tea almost as well as I can
addo
- Sara Watson's Stalker
- x 95
- x 8333
Never knew there was a Berlingo forum Adam...
If one half of the members are there then another good proportion can be found over on Club-XM...
Northern_Mike
I'm sure I've mentioned it before Jim..CitroJim wrote:Never knew there was a Berlingo forum Adam...
- x 1240
This one is actually working faster for me than the proper one! Thanks for the update Jim.
Clogzz
- x 40
Same here ... very fast !
- x 8333
You know what my memory is like MikeNorthern_Mike wrote:I'm sure I've mentioned it before Jim..CitroJim wrote:Never knew there was a Berlingo forum Adam...
ExcellentClogzz wrote:Same here ... very fast !
