c5 spheres
bill196510
c5 spheres
Unread post by bill196510 »
Worried about fitting them, needs sll 4
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
oneday
Re: c5 spheres
Unread post by oneday »
all 4 is the car solid with no suspension
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
was told it needed them when I got it, back can be pressed down, but front cant, but really bad over bumps, doesnt bottom though
Citroenmad
x 110
Re: c5 spheres
Unread post by Citroenmad »
Your C5 being a fully hydractive will have 6 spheres.
It doesn't need to have solid or no suspension to have to replace the spheres. If it does the spheres should have been replaced a long time before. However a harsh ride or a more springy ride will indicate a change is needed.
I
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
bill196510
Re: c5 spheres
Could it be the centre ones
x 1240
Re: c5 spheres
Unread post by Peter.N. »
Most likely, they are the ones responsible for the soft ride.
bill196510
Re: c5 spheres
How can I check which need replacing, £52 on ebay, is there any cheaper
x 1240
Re: c5 spheres
You can get paired ones a little cheaper but as the front and rear are different that is about the price. If you can check that it is switching into soft mode then the spheres will be the problem. Mileage will be a fair indicator, my 2.2 has done about 150k and they are still good but I have just replaced the fronts on the 2.0. at about 188k and they were pretty flat, the rears are even worse, I have some replacememnt but not fitted them yet.
bill196510
Re: c5 spheres
Might fit all 6
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I'm not a fan of guessing at spheres; easy to get them pressure tested by an indie. Ten percent loss on stamped rating is replacement time - unless you're game to drill and tap for the Tecnosir fittings.
bill196510
Re: c5 spheres
Tecnosir?
addo
x 95
It's an Italian-made system (they are a sphere maker) which uses screw-in valves that mean your spheres may be recharged several times in their life, by someone with a nitrogen bottle.
http://www.tecnosir.com/attrezzature_c720.php" onclick="window.open(this.href);return false;
http://www.tecnosir.com/ammortizzatori_ ... i.php?id=1" onclick="window.open(this.href);return false;
bill196510
Re: c5 spheres
Do you know of anyone who can do it
oneday
Re: c5 spheres
have a look at this place bill it may be what you are looking for
http://www.google.co.uk/url?sa=t&rct=j& ... cp3nxMumxw" onclick="window.open(this.href);return false;
306 1.4 LX MERIDIAN
bill196510
Re: c5 spheres
£450 for c5 :(
