Picasso Trim Levels
wigelywoo
Picasso Trim Levels
Unread post by wigelywoo »
Silly Question, but, How do I Know for certain what model my Xsara Picasso is.
No badge on tailgate.
There are two secrets to success
1. never reveal all you know
x 1489
Re: Picasso Trim Levels
POst up the last 8 digits of your VIN, and we'll get service.citroen to tell us :lol:
However: no air con = LX, manual aircon = SX, digital aircon / climate = Exclusive.
x 1489
service.citroen info below - no idea what 'high medium plus' is - but it sounds like Exclusive - this is a later one, and they did mess about with the trim on these....!
Vehicle family XSARA PICASSO
AS RPO No 10948 FV 2 0204
Warranty Start Date 09/01/2007
OPB P002
BER e2*98/14*0153*15
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XSARA PICASSO
SILHOUETTE FAMILY SALOON
TRIM LEVEL HIGH MEDIUM PLUS
ENGINE DIESEL TURBO DV6TED4 FAP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE DORICE "VD" VELOUR
UPHOLSTERY COLOUR "FD"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EV/DV
BADGE WITHOUT BADGE
Vehicle characteristics
STEERING POWER STEERING
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
ENGINE (TYPE) EV/DV
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
COOLING MOTOR RADIATOR TH : 32 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD POWER
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 140W
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 70
WHEEL STYLE 15 INCH MELBOURNE WHEEL
CLUTCH HYDRAULIC CLUTCH
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
TYRE (SIZE, TYPE) 185X65X15 H TYRES
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT ESP BOSCH 8 0
Body fittings
TOWBAR WITHOUT TOWBAR
WHEEL EMBELLISHER (STYLE) MELBOURNE STYLE
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT MIRROR ELECTRIC-FOLD BACK
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
EXTERIOR ACCESSORIES PAINTED EXT HANDLES+SIDE MOULDINGS+EXT MIRRORS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) TINTED
Interior fittings
REAR SEAT 3 SEPARATE REAR SEATS (3 SLIDING)
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
CONSOLE WITHOUT CONSOLE
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT CERBE CAPPING + PAINTED FRONT PANEL
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) MANUAL REAR BLIND
DRIVER SEAT ADJUSTMENT DRIVER’S LUMBAR SUPPORT
FRONT SEAT ARMREST FITTED WITH ARMREST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFT ELECT CNTRL RR WINDOW LIFTR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG DOUBLE FRONT LATERAL AIRBAG
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
ADDITIONAL AIR CONDITIONING WITHOUT ADDITIONAL AIR CONDITIONING
EXTERIOR REAR VIEW MIRROR (HEATED) HEATED DOOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL SPEED CONTROL
LOAD SPACE STORAGE REMOVABLE LOADING RUNNER + NET
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
TRIM ADAPTATION GEAR LEVER KNOB CHROME INSERT
STEERING WHEEL LEATHER STEERINGWHEEL
Electrical
ALTERNATOR ALTERNATOR 150 AMP
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
MULTIPLEXING MULTIPLEXING ASSEMBLY CAN VAN
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION DEPOLLUTION
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
SLAVE CONTROL UNIT BSI COMM 2000
wigelywoo
Does
Badge without Badge
mean
No exclusive badge on tailgate?
And does this mean mirrors should fold back, electronicly
