Citroen front wipers fault
alotmentman
Unread post by alotmentman »
help ive got a Citroen diesol 2001 model the front wipers have stopped working ive tested the motor and the wipers work with a direct connection of power from the battery ,,could you point me to were thw fuses and any other part that can be affecting them from working the washer for the water works ..of the arm also the rear wiper works of the control stick pleae help all advice apprecieted thanks :-D
Xantidote
x 4
Re: Citroën front wipers fault
Unread post by Xantidote »
And the model is ???
Martin
alotmentman
sorry about thar the model is a Citroen piccasso ,,,2001 diesol ,,,the back wiper works ,,so does the wiper washer pump at front ,,also if i dissconect the wiper at connection near motor i can get wipers to work with a direct feed of 12vpower can you point out which fuseses need checking and any other controls that might be causing the fault thanks afain
