gearbox drain
oneday
gearbox drain
Unread post by oneday »
does anyone know if you can drain the oil from a MK1 c5 manual gearbox. if you can where is the drain plug
306 1.4 LX MERIDIAN
x 1496
Re: gearbox drain
Course you can! Plug is on the bottom of the diff somewhere - quite possibly requires a square tool to undo it. Refilling is a bit more difficult as the official filler hole is on the back of the diff and inaccessible. Just fill the correct amount of oil via the breather on the top of the box. Oh, and ONLY use 75W80 spec oil.
oneday
Re: gearbox drain
thanks got the oil ready for it bv 75w80 did the engine oil today but couldnt see the gearbox drain
306 1.4 LX MERIDIAN
x 3298
Re: gearbox drain
In some Citroen gearboxes the reverse switch is on the top, (under the air filter box on a Xantia), and is an easier way to fill the 'box.
oneday
Re: gearbox drain
had a look at that today it looks a lot easier through the vent on the c5 you only have to remove the cap.
306 1.4 LX MERIDIAN
411514
(Donor 2017)
x 39
Re: gearbox drain
Unread post by 411514 »
The drain plug is there if you look hard enough. It is on the underside of the box, as opposed to the end and is a domed circular protrusion of about 5mm with a square drive in the centre, sam
Sam
2003 C5 2.0HDI 110
oneday
Re: gearbox drain
ye must admit i didnt look to hard it was cold and windy working outside
306 1.4 LX MERIDIAN
