How to adjusting ( soupape regulatrice )
ektor
Unread post by ektor »
How to adjusting ( soupape regulatrice ) 10 is photo?thank you
x 1238
Re: How to adjusting ( soupape regulatrice )
Unread post by Peter.N. »
Turning the screw clockwise increases the fuel flow. Only do this about half a turn at a time.
spider
x 77
Unread post by spider »
As Peter says.
Be aware it will smoke heavily if you adjust it too much and you may have to reset anti stall / idle / max unloaded speed settings as well.
To be fair the DW8 can be made a bit more lively with this compared to stock from what I've heard although the earlier units were a bit more lively anyway.
Andy.
ektor
please can you tell me when I understand that the soupape regulatrice is ok?thank you
x 1238
As much fuel as you can give it without it smoking excessively.
