Stopping frozen doors
VertVega
- x 13
Re: Stopping frozen doors
Up in north car owners use a product called Silicone Stick for preventing door seals sticking.
It happens especially in the beginning of winter (humid & cold) or after car wash during winter.
May be you should look for a similar product.
From the manufacturer's pages:
"Protective agent for sealants. Keeps rubber soft and supple. Prevents sealants from chipping,
breaking and freezing. Removes squeaky noises.
Application: Squeeze some liquid onto a sponge, spread on the surface. Close the stick carefully after use."
Bannedbiker
- x 3
My Xantia does this in the cold weather too, has done the last 3 winters but goes back to normal as soon as the warmer weather comes.Mandrake wrote:
Also when de-icing the rear window this morning I noticed this:
The rubber has completely curled around away from both the glass and the metal leaving gaping gaps.As far as I know before the last few days of freezing weather the rubber was fine - I would have noticed something like this if it had happened earlier.
My question is, has the cold temperature and ice caused this damage, or has it been liberal use of de-icer in the last few days that has swelled the rubber up ?Anything I can do to fix it ?
Roll on Summer!!!!
Martin.
2003 Peugeot 307, 1.6 petrol.
Previously owned 1999 Citroen Xantia 1.9 td and a 1997 Citroen ZX 1.9
Xantippa
- x 29
Here in Finland we use silicone-stick like this:
It works well, and it´s easier to apply than spray.
- x 695
Just what the doctor ordered....now where to find something like that in the UK...Xantippa wrote:Here in Finland we use silicone-stick like this:
- x 695
Well I was in a bit of a hurry to get to work and the rubber was very stiff in the cold and wouldn't budge anyway. I think I'll have to wait for mid day tomorrow for it to warm up enough to make the rubber pliable again before I can tease it back into position. Perhaps some silicon treatment (along with the door seals) will prevent it happening again.Citroenmad wrote:
That does look very strange!
Did you try and pull the top of it from under the glass? Perhaps that will flatten it out. It shouldnt be a reacion to the de-icer, but you never know.
Xantidote
- x 4
Yes, mine too. Only the length of seal which lies horizontally on the hatch/tailgate seems to affected. Started 1-2 winters ago, and yes, it disappears again when weather gets warmer. Maybe the rubber is degrading with long term exposure to sunlight/UV?Bannedbiker wrote:My Xantia does this in the cold weather too, has done the last 3 winters but goes back to normal as soon as the warmer weather comes.
Martin
1995 Xantia TDLX (deceased
- x 695
Checked the seal today, the rubber along the bottom of the glass is soft and flimsy in the cold - I can push it back into place but its so soft that it doesn't hold it's shape. It's also doing it on the right hand side. If there was a heavy downpour the water would go straight into the boot. I guess it just needs a new rubber seal
Jaine
I used silicone spray on a cloth on the Williams & it worked great this morning.
Jaine
Jaine
If I throw a stick, will you leave?.
- x 5672
I meant to do that today but by the time I had fixed the lights it had been completely forgotten. Will probably have to break into the car with a lump hammer and crowbar tomorrow.Jaine wrote:I used silicone spray on a cloth on the Williams & it worked great this morning.
Jaine
- x 695
Looks like getting ice off the car is the least of my worries now, the snow has begun:
(spot the Xantia) Will be interesting to see how my Michelin Energies cope in the snow. They're not winter tyres but still street loads better than the nearly bald, junk tyres that graced the front wheels a few months ago. Before the snow fall the car park was already an ice skating rink that was scary and slippery to walk on but I had been driving in and out of it without problems but tomorrow will be a new test, and the first time I've ever driven a car in snow.
The roads around here are usually gritted so shouldn't be a problem but in previous winters the neighbours have had trouble getting in and out of the car park, especially up the slight incline from the main road...
andy5
- x 103
Thanks to this discussion I've bought one of these stick products - the German one
Doing a search for silicone stick produced some other kinds of results
- x 695
Same problem here.andy5 wrote:Thanks to this discussion I've bought one of these stick products - the German one
andy5
- x 103
gummi pflege on ebay, from 5.95
mooseshaver
I ordered my gummi from eBay too. Not arrived yet so can't review
C5 III Tourer 2.0 HDi 163 Auto Exclusive
Gone cars.
C5 2.2 HDi Exclusive Estate auto 57. Awesome car. Sadly Could not be fixed by Citroen.
C5 1.6 HDi VTR Estate 56. Traded in.
C5 2.2 HDi SX Estate 02. Drowned in the floods of 09.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
Johnny Cogs
You'll probably all larf at this... but when I had the s1 estate and that was all frozen up, I would lob a couple of buckets of water over it... Was enough to clear the windows, unstick the doors and electric windows and get her running... Used to heat up real quick too (1.9td vsx) so only took a couple of mins to get motoring...
'rolls in a 1.9TD Syn-bus!'
