x 8406
Re: Citrojim's Xantia and XM Tales
Xac wrote:It's a pity they can't sort it out for you to provide remote support from home Jim
Yes, it is really but sadly my job is not one that is very amenable to remote working...
Speaking to someone today it would appear one solution might be a quiet area where I can crash out at times of need and take on a bit of a recharge :wink: It comes under the guise of workplace adaptations and they must apparently do their best to accommodate such needs...
bxzx16v
x 34
Unread post by bxzx16v »
Its good to hear your back at work Jim , did flux's give you a good deal on your fleet then .
Mark
Citroenmad
x 110
Unread post by Citroenmad »
Good news with the cheaper insurance on the XM Jim :-D I bet your V6 is pleased to be back in use, well, it might be until it sees the salty roads! :lol:
Im with Adrian Flux, they always find exactly what im after and at a good price too. They usually have a wobble at renewal time andincrease my premium by about £150-£200 but after a phone call its resolved.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 8406
bxzx16v wrote:Its good to hear your back at work Jim , did flux's give you a good deal on your fleet then .
Only on the XM Mark. I remain with a brilliant deal with Admiral for the moderns...
I was well impressed with Flux's customer service - possibly just a bit better than Admiral..
Citroenmad wrote:I bet your V6 is pleased to be back in use, well, it might be until it sees the salty roads! :lol:
Bilt Hamber to the rescue :wink: :lol:
spider
x 77
Unread post by spider »
I take it this was not your V6 then being 'tested'...
:-D
I actually found that on Youtube while looking for something else, a quick screengrab seemed sufficient.
Andy.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Lol, firstly An S2 Xantia, secondly, the rev counter has suffered the "Flat Battery" Syndrome at some point, because, no thats not reving off the clock, its flipped round, thirdly that has to be a V6, nothing else Xantia goes that fast, and WOW look at those K's its done, 341,000 KMilometers!!!
He was probably trying to get theneedle right round to see if it would flip the revs back to normal.. :lol: :lol: :lol:
A very sad...
1994 XM 2.1 d auto
spider
x 77
Yes > " onclick="window.open(this.href);return false; (may want to turn sound down though) Figured the tacho needle was stuck due to the flat battery concern. :D
Andy.
x 8406
Interesting as that instrument set has oil and coolant temperature gauges next to each other. UK models have the fuel and coolant temperature gauges next to each other with a gear position repeater in the traditional location of the oil temperature gauge on the opposite side.
That's a fair old speed he's knocking on at and judging by where the temperature gauges are the engine is working hard...
I'm thinking that might be a manual having covered that sort of mileage...
Thanks for sharing Andy... As it happens I've never been that fast in all my life!
I've taken advantage of the nice weather today and given my V6 a bit of a check-over. The front brakes were a bit noisy and graunchy so I've stripped the calipers and cleaned them up. They were a bit corroded and sad after being unused for so long. A lot better now...
I also replaced the windscreen wipers as they were getting a bit worn and shuddering a bit in light rain...
Touch-wood she's all good for the winter now. Whilst I was in the mood I gave the XM a routine check and nothing to report :-D
citroenxm
Fallen Hero
x 70
Jesse.. i never noticed those gauges...sharp eye..
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
Impressive! Just a little over 141mph. Well, knowing how accurate a Xantia speed is, its probably more like 130ish. :lol:
Im also impressed with its mileage, a very nicely used Xantia 8-)
03 Seat Arosa 1.0S
citroenxm
Fallen Hero
x 70
Its not caught mine up though Chris.. mines an equlivent 366,000 km....
A very sad...
1994 XM 2.1 d auto
spider
x 77
CitroJim wrote:Speaking to someone today it would appear one solution might be a quiet area where I can crash out at times of need and take on a bit of a recharge :wink: It comes under the guise of workplace adaptations and they must apparently do their best to accommodate such needs...
That does sound like a satisfactory compromise where remote working is not possible for various reasons. Lets hope it does work out well, I'm sure it will though as from what you've said so far they are quite flexible it seems. :) , then again good employee's are well worth the employer going the "extra mile" for in all cases, something I sort of wish mine had done although my specifics were different and looking back I do not now think it would of helped me. For you it certainly will from what I've read anyway. :)
Andy.
x 8406
That's the secret Andy, a afternoon recharge...
Even today when I will confess to not doing much this morning I still found the afternoon crash was a mandatory requirement*. An hour has recharged me quite well - as evidenced by my posting on here and the other forum I frequent... :-D
* Whether I want to or not I fall asleep anyway...
KP
x 27
Unread post by KP »
citroenxm wrote:Its not caught mine up though Chris.. mines an equlivent 366,000 km....
Come on paul thats not too far behind mine...
:whip1: [-( blah2: :pp:
270 900 miles = 435 971.29 kilometres
citroenxm
Fallen Hero
x 70
When i fix my cutting out issue then ill have more confidence .. but until then and brass allows.. She will be reduced mileage...
A very sad...
1994 XM 2.1 d auto
