How do you reset fuel additive reading with lexia on C5 2001
horsedentist
Hi Guys
I have refilled my additive tank today but can't for the life of me find the right section on lexia that will tell the ecu that it is now full. I tried diesel additive personal maintenance but it says this feature not available on this model and all I can find in the diesel additive section is the quantity to inject? Idiots map to the right section would be appreciated ta .
Eric
Eric
DickieG
- Monaco's youngest playboy
- x 38
Re: How do you reset fuel additive reading with lexia on C5
As I understand it on some early C5's you cannot reset the additive ecu, its a case of fitting a new replacement.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
horsedentist
That would be it then, in configuration the only options are replace particle filter and replace additive ecu. Bit bloomin stupid considering you should be able to reprogram an ecu more money grabbing me thinks.
- x 1240
I reset my 01 2.2 with the lexia after putting a litre of fluid in and it hasn't come up again since, I just deleted all the faults.
horsedentist
I tried deleting the faults but it returns "Permanent fault still present" ?Peter.N. wrote:I reset my 01 2.2 with the lexia after putting a litre of fluid in and it hasn't come up again since, I just deleted all the faults.
Eric
- x 1240
Oh, don't know I'm afraid I amd still very much a novice with the lexia.
horsedentist
Yes that is my problem tooPeter.N. wrote:Oh, don't know I'm afraid I amd still very much a novice with the lexia.
Eric
- x 1240
I'm still trying to find out how to reprogramme my key fob.
horsedentist
I would assume that comes under replacement parts but if I click on that on mine it says "this function not available on this model"
spider
- x 77
DickieG wrote:As I understand it on some early C5's you cannot reset the additive ecu, its a case of fitting a new replacement.
Andy.
horsedentist
My thoughts exactly any one else got any theories??spider wrote:DickieG wrote:As I understand it on some early C5's you cannot reset the additive ecu, its a case of fitting a new replacement.That's a bit shocking to find out.
paulcornwall
Did anyone find the instructions to reset the values in Lexia when refilling with diesel additive??
waynedance
- x 8
I reset mine with a Launch diagnostic machine.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Diabolical
SamePeter.N. wrote:I'm still trying to find out how to reprogramme my key fob.
06 C5 2.0L HDi Exclusive Estate 20020k and rising.
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
citroencx.co.uk
citroenxm
- Fallen Hero
- x 70
Key programming is in the Configuration menu for the BSI IIRC...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
