Xantia suspension gaiter
Xaccers
x 188
Re: Xantia suspension gaiter
Unread post by Xaccers »
citronut wrote:
CitroJim wrote:I don't think you'll get it up past the leak-back foot or the drop link tab Malcolm. The gaiters are not very stretchy... they're made of plastic rather then rubber...
Plus you'd have to disconnect the drop link and that may entail use of an angel grinder and thus the destruction of an otherwise perfect drop link...
ok
i had forgotten about the drop link bracket :roll:
i'll go sit in the naughty corner :oops: :wink:
DIY sphere tool
x 3303
Nah, not the naughty corner (you didn't suggest it to cause a problem), just the silly prats' corner (once I get out of it!).
x 94
Unread post by citronut »
Hell Razor5543 wrote:Nah, not the naughty corner (you didn't suggest it to cause a problem), just the silly prats' corner (once I get out of it!).
havent we got a senior moment corner yet :-D :roll: :wink:
Regards, malcolm.
x 3303
As far as I can tell, the seniors on this forum usually know what they are doing, how to fix problems, or where to find the information to get things working. They don't have time for senior moments!
Xaccers
x 188
Hell Razor5543 wrote:As far as I can tell, the seniors on this forum usually know what they are doing, how to fix problems, or where to find the information to get things working. They don't have time for senior moments!
It's OK lads, looks like our cover hasn't been blown yet ;)
DIY sphere tool
x 8349
citronut wrote: havent we got a senior moment corner yet :-D :roll: :wink:
When we have I'll come and join you in it Malcolm :lol: :roll:
x 5671
I'll shove over and make a space for you two.
x 94
i hope thats a feline darlek in your avatar Steve
Regards, malcolm.
x 5671
Unfortunately - or fortunately depending on your viewpoint, no Malcolm.
It is of the order Sphenisciformes, family Spheniscidae as with Jim's and for similar reasons.
Image Image
x 3303
I've heard a rumour about where the senior moment corner is. What's the name of your local, CitroJim? The Plough, isn't it?
Xaccers
x 188
I love it when people flip that switch :)
DIY sphere tool
x 94
can we hijack smiley's from the BXC forum as they have one rolling on the floor laughing
Regards, malcolm.
Chris570
x 36
Unread post by Chris570 »
Sorry to make a post about the topic (highly irregular i know) BUT the best way by far that i've found is to remove the strut top (for inspection as previously suggested) and then fit the piston into the strut top and do up the nut a few turns and then put the strut top back. saves mucking about really.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
x 8349
Chris570 wrote:Sorry to make a post about the topic (highly irregular i know)
It's an offence that could lead to a ban if you persist Chris :wink: :lol:
Jaf
x 42
Unread post by Jaf »
Well got them fitted. Thanks for all the help and laughs! Needed a bit of help holding the wheel straight whilst pushing the piston back up but apart from that all went to plan. Good job I replaced both gaiters as though the pasenger side looked fine once I started to remove it it crumbled in my hands. Strut tops looked OK but the bump stops are a little worn so I'll replace those at some point and check the strut tops again.
Thanks again.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
