Fault codes P0180 and P1112
stu9
x 8
Unread post by stu9 »
C5 2.0hdi
P0180 is seemingly...
Possible causes of OBD code P0180
- Harness or connectors (The sensor circuit is open or shorted) - Fuel tank temperature sensor may be faulty The Error code is generally activated on detection of the following conditions: - An excessively high or low voltage is sent to ECM. - Rationally incorrect voltage is sent to ECM, compared with
And..
P1112 is a high pressure leak....the Lexia said Fuel fault - high pressure (leak)
I dont know how to work it properly yet to find out exactly where and what I need....Jim did say It told you, maybe need to get him to help me through it
Where do I find them....and what do I clean, fix or replace ?
I've got 2 others, but they're the main ones just now
stu9
x 8
Re: Fault codes P0180 and P1112
My god....i thought after folk saying to get the codes, someone would have know or been able to help
stu9
x 8
Anyone ?
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
No idea stu, sorry..
I cant even read my codes.. my generic OBD has a communication error with the C5, and I have no lexia..
Was supposed to be driving to belgium on Saturday but dont want to risk it really..
oneday
Unread post by oneday »
hi stu are these fresh codes ie did you wipe the codes from the memory then take the car for a run and read the codes again to make sure the codes are fresh and not left from some previous fault
306 1.4 LX MERIDIAN
stu9
x 8
Yes they're fresh that's why I put them up
oneday
P1112 Intake air temperature (IAT) sensor circuit Intermittent low voltage
this is what i see when i look at the fault code list. the othe one i can find no mention of
P1XXX - Miscellaneous
P1000 EDC15C2 - CAN communication. Automatic gearbox
P1003 EDC15C2 - External intervention on the flow. Automatic gearbox function information; value received incorrect
P1012 EDC16C3 - Particle emission filter (PEF). Maximum number of aborted regenerations reached.
P11XX - Fuel and Air Metering
P1100 MAF (Mass Air Flow) sensor intermittent / Systems check not complete
P1101 MAF (Mass Air Flow) sensor Out of self test range
P1102 MAF (Mass Air Flow) sensor in range but lower than expected
P1103 MAF (Mass Air Flow) sensor in range but higher than expected
P1104 MAF (Mass Air Flow) ground malfunction
P1105 Dual alternator upper fault
P1106 Dual alternator lower fault / MAP (Manifold Absolute Pressure) sensor circuit Intermittent high voltage
P1107 Dual alternator lower circuit malfunction / MAP (Manifold Absolute Pressure) sensor circuit Intermittent low voltage (EDC15C2-Swirl solenoid valve)
P1108 Dual alternator battery lamp circuit malfunction / Baro to MAP (Manifold Absolute Pressure) sensor comparison too high.
EDC15C2 - Fan high speed circuit. Open circuit or short circuit to earth.
P1109 Intake air temperature (IAT) B sensor intermittent
P1110 Intake air temperature (IAT) sensor (D/C) open/short.
S2000 - Adaptation of the quantity of air entering the manifold.
EDC15C2 - Airconditioning cut-off circuit. Open circuit or short circuit to earth.
P1111 Intake air temperature (IAT) sensor circuit Intermittent high voltage
EDC15C2 - Diesel high pressure monitoring function. Pressure lower than the minimum pressure. (leak).
MM4MP2 - Motorised throttle control.
P1113 Intake air temperature (IAT) sensor circuit open/short
EDC16C3 - Diesel high pressure regulation circuit. Rail pressure below minimum pressure.
P1114 Engine coolant temperature (ECT) sensor circuit Intermittent low voltage / IAT - B sensor circuit low input
P1115 Engine coolant temperature (ECT) sensor circuit Intermittent high voltage / IAT - B sensor circuit high input
P1116 Engine coolant temperature (ECT) sensor out of range
P1117 Engine coolant temperature (ECT) sensor circuit Intermittent
P1118 Manifold absolute temperature sensor circuit Low input
P1119 Manifold absolute temperature sensor circuit High input
P1120 Throttle position sensor (TPS) out of range
P1121 Throttle position sensor (TPS) circuit Intermittent high voltage
P1122 Throttle position sensor (TPS) circuit Intermittent low voltage
P1123 Throttle position sensor (TPS) In range but higher than expected
P1124 Throttle position sensor (TPS) Out of self test range
P1125 Throttle position sensor (TPS) circuit Intermittent
P1126 Throttle position sensor (TPS) circuit (Narrow range) Malfunction
P1127 Exhaust not warm Downstream oxygen sensor
P1128 Upstream heated oxygen sensor (HO2S) Swapped
P1129 Downstream heated oxygen sensor (HO2S) Swapped
P1130 Lack of HO2S switching - Adaptive fuel at limit
P1131 Lack of HO2S switching - Sensor indicates lean
P1132 Lack of HO2S switching - Sensor indicated rich / EDC15C2-Catalytic convertor temperatures
P1133 HO2S 1 Insufficient switching
P1134 HO2S 1 Transition time ratio
P1135 Pedal position sensor circuit A Intermittent
EDC15C2 - 3rd piston deactivation. Short circuit to earth or open circuit.
Toyota 2.0 VVTi - Malfunction of the heater circuit, bank 1 upstream O2 sensor.
P1136 Fan control circuit Malfunction
P1137 Lack of HO2S 2 switching - Sensor indicates lean
P1138 High pressure rail sensor fault / Lack of HO2S 2 switching - Sensor indicates rich
EDC15C2 - Fuel pressure. Stop requested but regulator still active.
P1139 Water in fuel indicator circuit Malfunction
P1140 Water in fuel condition
P1141 Fuel restriction indicator circuit Malfunction
P1142 Fuel restriction Condition
P1143 Air assist control valve Range / Performance
P1144 Air assist control valve circuit Malfunction
P1145 Lucas DCN2 - Noise on the needle lift sensor. Incoherence
P1150 Lack of HO2S 21 switching - Adaptive fuel at limit
MM4MP2 - Throttle position captor, check. Coherence.
P1151 Lack of HO2S 21 switching - Sensor indicates lean
P1152 Lack of HO2S 21 switching - Sensor indicated rich
P1153 Bank 2 Fuel control shifted lean.
MM6LP - Throttle stop learning. Malfunction
ME744 - Motorised butterfly
P1154 Bank 2 Fuel control shifted rich
P1155 Alternative fuel controller
P1156 Fuel select switch malfunction
P1157 Lack of HO2S 22 switching - Sensor indicates lean
P1158 Lack of HO2S 22 switching - Sensor indicates rich
P1159 Fuel stepper motor Malfunction
P1161 S2000PM1 - Throttle position copy
P1162 SIRIUS 81 - Exhaust gas recirculation. Coherence.
P1164 Fuel pressure sensor test
SID 801 - Fuel pressure signal.
P1165 SID 803 - Fuel Pressure signal. Pressure change coherence.
P1167 Invalid test throttle not pressed
AL4 - Fault in pressure regulation - variation/recommendation.
P1168 Fuel rail sensor In range low failure
P1169 Fuel rail sensor In range high failure / EDC15C2-Condenser 1 voltage
P1170 Engine shut off (ESO) solenoid Fault / EDC15C2-Condenser 2 voltage
P1171 Rotor sensor Fault / EDC15C2-Engine stop test by injector cut-off
P1172 Rotor control Fault
P1173 Rotor calibration Fault
P1174 Cam sensor Fault
P1175 Cam control Fault
P1176 Cam calibration Fault
SID802 - Fuel flow regulation fault. Coherence.
P1177 Synchronisation Fault
SID802 - Fuel flow regulation fault. Short circuit to ground.
P1178 (open)
P1179 SID802 - Fuel flow regulation fault. Short circuit between 2 wires.
P1180 Fuel delivery system Malfunction - low
SID802 - Fuel flow regulation fault. Open circuit or short to positive.
P1181 Fuel delivery system Malfunction - high
P1182 Fuel shut off solenoid Malfunction
P1183 Engine oil temperature circuit Malfunction
P1184 Engine oil temperature Out of self test range
P1185 Fuel pump temperature sensor (FTS) high
P1186 Fuel pump temperature sensor (FTS) low
P1187 Varient selection
P1188 Calibration memory fault
P1189 Pump speed signal Fault
P1190 Calibration resistor out of range
P1191 Key line voltage
P1192 Voltage external
P1193 EGR drive Overcurrent
P1194 ECU A/D converter
P1195 SCP HBCC Failed to Inititialise
P1196 Key off voltage high
P1197 Key off voltage low / Piezo-electric injector, power stage
P1198 Pump rotor control Underfuelling
SID801 - Diesel high pressure monitoring. Flow regulator (VCV) at stop.
P1199 Fuel level Input circuit low
P12XX - Fuel and Air Metering
P1200 Injector control circuit
EDC16C3 Diesel high pressure monitoring. Maximum pressure exceeded.
P1201 Injector circuit open/shorted - cylinder #1
P1202 Injector circuit open/shorted - cylinder #2
P1203 Injector circuit open/shorted - cylinder #3
P1204 Injector circuit open/shorted - cylinder #4
P1205 Injector circuit open/shorted - cylinder #5
P1206 Injector circuit open/shorted - cylinder #6
P1209 Injector control pressure system Fault
P1210 Injector control pressure above expected level
P1211 Injector control pressure sensor above/below desired
P1212 Injector control pressure Not detected during crank
P1213 Start injector circuit Malfunction
P1214 Pedal position sensor B circuit Intermittent
P1215 Pedal position sensor C circuit low input
P1216 Pedal position sensor C circuit high input
P1217 Pedal position sensor C circuit Intermittent
P1218 CID high
P1219 CID low
P1220 Series throttle control system Malfunction
P1221 Traction control system Malfunction
P1222 Traction control output circuit Malfunction
P1223 Pedal demand sensor B circuit high input
P1224 Throttle position sensor B out of self test range
P1225 Needle lift sensor Malfunction
P1226 Control sleeve sensor Malfunction
P1227 Wastegate failed closed (over pressure)
P1228 Wastegate failed open (under pressure)
P1229 Intercooler pump driver Fault
P1230 Fuel pump low speed Malfunction
P1231 Fuel pump secondary circuit low high speed
P1232 Fuel pump primary speed circuit Malfunction
P1233 Fuel pump driver module Off line
P1234 Fuel pump driver module Off line
P1235 Fuel pump control Out of range
P1236 Fuel pump control Out of range
P1237 Fuel pump secondary circuit Malfunction
P1238 Fuel pump secondary circuit Malfunction
P1239 Speed fuel pump position feed Fault
P1240 Sensor power supply Malfunction
P1241 Sensor power supply Low input
P1242 Sensor power supply High input
P1243 Second fuel pump faulty or ground fault
P1244 Alternator load input failed High
P1245 Alternator load input failed Low
P1246 Alternator load input failed
P1247 Turbo boost pressure Low
P1248 Turbo boost pressure not detected
P1249 Wastegate control valve performance
P1250 PRC solenoid circuit Malfunction
P1251 Air mixture solenoid circuit Malfunction
P1252 Pedal correlation PDS1 & LPDS High
P1253 Pedal correlation PDS1 & LPDS Low
P1254 Pedal correlation PDS2 & LPDS High
P1255 Pedal correlation PDS2 & LPDS Low
P1256 Pedal correlation PDS1 & HPDS
P1257 Pedal correlation PDS2 & HPDS
P1258 Pedal correlation PDS1 & PDS2
P1259 Immobiliser to PCM signal error
P1260 Theft detected Vehicle immobilised
P1261 Cylinder #1 High to Low short
P1262 Cylinder #2 High to Low short
P1263 Cylinder #3 High to Low short
P1264 Cylinder #4 High to Low short
P1265 Cylinder #5 High to Low short
P1266 Cylinder #6 High to Low short
P1267 Cylinder #7 High to Low short
P1268 Cylinder #8 High to Low short
P1269 Immobiliser Code not programmed
P1270 Engine RPM or speed limiter reached
P1271 Cylinder #1 High to Low open
P1272 Cylinder #2 High to Low open
P1273 Cylinder #3 High to Low open
P1274 Cylinder #4 High to Low open
P1275 Cylinder #5 High to Low open
P1276 Cylinder #6 High to Low open
P1277 Cylinder #7 High to Low open
P1278 Cylinder #8 High to Low open
P1280 Injection control pressure Out of range Low
P1281 Injection control pressure Out of range High
P1282 Excessive injection control pressure
P1283 IPR circuit failure
P1284 Aborted KOER - ICP failure
P1285 Cylinder head over temp sensed
P1286 Fuel pulse In range but Lower than expected
P1287 Fuel pulse In range but Higher than expected
P1288 Cylinder head temp sensor Out of self test range
SIRIUS81 (EW10D) - Fuel rail pressure. Low value received.1
P1289 Cylinder head temp sensor High input
EW10J4S - Dual inlet. Activation of second air intake duct. Circuit malfunction
P1290 Cylinder head temp sensor Low inp
EW10J4S - Dual inlet. Activation of second air intake duct. Performance field
P1291 Injector High side short to GND or VBATT - Bank 1
SIRIUS81 (EW10D)- Fuel pressure regulation fault. Output/Locking.
Fuel rail pressure. Low value received.2
P1292 Injector High side short to GND or VBATT - Bank 2
EW10J4S - Dual inlet. Activation of second air intake duct. Circuit, lower malfunction
P1293 Injector High side open - Bank 1
EW10J4S - Dual inlet. Activation of second air intake duct. Circuit, upper malfunction
P1294 Injector High side open - Bank 2/Target idle not reached
SIRIUS81 (EW10D) - Fuel rail pressure. High value received.1
P1295 Multi-faults - Bank 1 - with low side shorts
EW10J4S - Dual inlet. Activation of second air intake duct. Intermittent circuit
P1296
Multi-faults - Bank 2 - with low side shorts
Additive injector. Open circuit
P1297
Injector high sides shorted together
SIRIUS81 (EW10D) - Fuel rail pressure. High value received.2
P1298
IDM failure
Additive injector. Circuit, upper breakdown
P1299
Cylinder head overtemperature protection active
Additive injector. Circuit, lower breakdown
P13XX - Ignition system
P1300
Boost calibration fault
P1301
Boost calibration High
P1302
Boost calibration Low
P1303
EGR calibration fault
P1304
EGR calibration High
P1305
EGR calibration Low
P1306
Kickdown Relay pull - In circuit fault
P1307
Kickdown Relay Hold circuit fault
P1308
A/C clutch circuit fault
P1309
Misfire monitor AICE chip fault
P1313
Misfire rate Caltalyst damage fault - Bank 1
P1314
Misfire rate Catalyst damage fault - Bank 2
P1315
Persistent misfire
P1316
Injector circuit IDM codes detected
P1317
Injector circuit IDM codes not detected
P1327
S2000P - Ignition - Integrated Phase detection
P1336
Crank/Cam sensor range/performance
S2000PM1/2 - High misfire on several cylinders
ME7.4.5. Combustion misfiring on unspecified cylinders.
P1338
ME7.4.5. Cylinder No.2 misfires.
P1340
Camshaft position sensor B circuit Malfunction
P1341
Camshaft position sensor B range/performance
P1345
SGC (cam position) sensor circuit Malfunction / Crankshaft
P1346
Fuel level sensor B circuit Malfunction
P1347
Fuel level sensor B range / performance
P1348
Fuel level sensor B circuit Low
P1349
Fuel level sensor B circuit High
P1350
Fuel level sensor B Intermittent/Bypass line monitor
SID 801 - Pre/Post heating relay circuit - Short or Open circuit, including Pre-Heat plugs
EDC16C34 - Preheating relay circuit control in short circit to earth or open circuit. (Check battery status).
P1351
IDM input circuit Malfunction/Ignition coil control circuit High voltage
SID 803/EDC16C3 - Pre/Post heating relay circuit. Relay not controlled and glow plugs supplied.
P1352
Ignition coil A Primary circuit Malfunction / SID 801- Pre/Post heating relay circuit - Relay & Pre-Heat plugs not controlled
P1353
Ignition coil B Primary circuit Malfunction
P1354
Ignition coil C Primary circuit Malfunction
P1355
Ignition coil D Primary circuit Malfunction
P1360
Ignition coil A Secondary circuit Malfunction
P1361
Ignition control (IC) circuit Low voltage
P1362
Ignition coil C Secondary circuit Malfunction
P1363
Ignition coil D Secondary circuit Malfunction
P1364
Ignition coil Primary circuit Failure
P1365
Ignition coil Secondary circuit Failure
P1366
Ignition spare
P1367
Ignition spare
P1368
Ignition spare
P1369
Engine temperature light monitor Malfunction
P1370
Insufficient RMP increase during spark test
P1371
Ignition coil - Cylinder #1 - Early activation fault
P1372
Ignition coil - Cylinder #2 - Early activation fault
P1373
Ignition coil - Cylinder #3 - Early activation fault
P1374
Crankshaft position (CKP) / Ignition coil - Cylinder #4 - Early activation fault
P1375
Ignition coil - Cylinder #5 - Early activation fault
P1376
Ignition coil - Cylinder #6 - Early activation fault
P1380
Misfire detected - Rough road date not available
P1381
Variable Cam timing Overadvanced (Bank #1) / Misfire detected no communiction with BCM
P1382
Variable Cam timing solenoid #1 circuit Malfunction
P1383
Variable Cam timing Overretarded (Bank #1)
P1384
VVT solenoid A Malfunction
P1385
Variable Cam timing solenoid B Malfunction
P1386
Variable Cam timing Overadvanced (Bank #2)
P1387
Variable Cam timing solenoid #2 circuit Malfunction
P1388
Variable Cam timing Overretarded (Bank #2)
P1389
Glow plug circuit High side Low input
P1390
Octane adjust pin out of self test range
P1391
Glow plug circuit Low input (Bank #1)
P1392
Glow plug circuit High input (Bank #1)
P1393
Glow plug circuit Low input (Bank #2)
P1394
Glow plug circuit High input (Bank #2)
P1395
Glow plug monitor Fault (Bank #1)
P1396
Glow plug monitor Fault (Bank #2)
P1397
System voltage Out of selt test range
P1398
VVT solenoid B circuit High input
P1399
Glow plug circuit High side High input
P14XX - Auxiliary Emission Controls
P1400
DPFE circuit Low input
P1401
DPFE circuit High input
P1402
EGR metering Orifice restricted
Lucas DCN2 - EGR butterfly solenoid valve control. Short circuit to earth or short circuit to positive or open circuit.
EDC15C2 - EGR: Throttle electrovalve. Short circuit to earth or open circuit.
P1403
Additional heating circuit 1
EDC16C3 - Additional heating circuit 1. Short circuit to earth, short circuit to positive, open circuit or actuator.
P1404
IAT - B circuit Malfunction / EGR closed position performance
EDC15C2 - Additional heating circuit 2 and pre-heat
EDC16C3 - Additional heating circuit 2. Short circuit to earth, short circuit to positive, open circuit or actuator.
P1405
DPFE sensor upstream Hose off or plugged
P1406
EGR position sensor performance
P1407
EGR No flow detected
P1408
EGR Flow out of selt test range
EDC15C2-Additional heating circuit
P1409
EVR control circuit Malfunction
P1411
SAI system incorrect downstream flow detected
EDC15C2-Converter upstream temperature
P1413
SAI system monitor circuit Low input
P1414
SAI system monitor circuit High input
P1415
Air pump circuit Malfunction / Air system bank 1
P1416
Port air circuit Malfunction / Air system bank 2
EDC15C2-Converter downstream temperature
P1417
Port air relief circuit Malfunction
P1418
Split air #1 circuit malfunction
P1419
Split air #2 circuit malfunction
P1420
Catalyst temperature sensor failure
P1421
Catalyst damaged
P1422
EGI temperature sensor failure
P1423
EGI functionality test failed
P1424
EGI Glow plug Primary failure
P1425
EGI glow plug Secondary failure
ED15C2 with FAP - Catalytic converter downstream temperature signal. Short circuit to positive or open circuit or Coherence between converter 1 & 2 temperature signal.
P1426
EGI mini MAF failed Out of range
P1427
EGI mini MAF failed Short circuit
P1428
EGI mini MAF failed Open circuit
P1429
Electric air pump Primary failure
EDC15C2 Particulate Differential pressure sensor value. Coherence of the differential pressure when stopped.
P1430
Electric air pump Secondary failure
P1433
A/C Refrigerant temperature circuit Low
P1434
A/C Refrigerant temperature circuit High
P1435
A/C Refrigerant temperature circuit Range/Performance.
EDC15C2 - Additive adding system. Faults additive accuracy.
EDC15C2 - Additive system. Fuel gauge fault.
EDC15C2 - Additive system. Low additive level sensor fault.
EDC15C2 - Additive system. Fuel filler cap present sensor fault.
EDC15C2 - Additive system. Faults additive pump.
EDC16C3 - Additive system. Value received by the CAN network incorrect.
P1436
A/C Evaporator air temperature circuit Low
P1437
A/C Evaporator air temperature circuit High
P1438
A/C Evaporator air temperature circuit Range/Performance
P1439
Floor temperature switch circuit malfunction
P1440
Purge valve stuck open
P1441
Evaporative emission (EVAP) system flow during non-purge (Oldsmobile / Chevrolet only)
P1442
Evaporative emission control system Leak detected
EDC15C2-Quantity of additive Additive ECU.
P1443
Evaporative emission control system control valve
P1444
Purge flow sensor circuit Low input
P1445
Purge flow sensor circuit High input
EDC16C3 - Additive system. Quantity of additive too high.
P1446
Evaporative vac solenoid circuit malfunction
EDC15C2-(607) Additive level.
EDC15C2-(307/406) Additive quantity. Additive minimum level wait.
P1447
ELC system closure valve Flow fault
EDC15C2 - PEF filter pierced or differential pressure incorrect. / PEF: Particle emission filter. Clogged particle filter.
P1448
ELC system 2 fault
EDC15C2 PEF: Particulate emission filter overloaded.
P1449
Evaporative check solenoid circuit malfunction
P1450
Unable to bleed up fuel tank vacuum
P1451
Evaporative emission control system vent control valve circuit
P1452
Unable to bleed Up vacuum in tank
P1453
Fuel tank pressure relief valve malfunction
P1454
Evaporative system vacuum test malfunction
P1455
Evaporative emission control system Leak detected (Gross leak / no flow)
P1456
Fuel tank temperature sensor circuit malfunction
P1457
Unable to pull vacuum in tank
P1458
Coolant solenoid valve Short to earth or open circuit.
P1460
Wide open throttle A/C cutoff relay circuit
P1461
A/C pressure sensor circuit Voltage Low
SID 803 - EGR valve. Learning
P1462
A/C pressure sensor circuit Voltage High
P1463
A/C pressure sensor Insufficient pressure change
P1464
A/C demand Out of self test range
P1465
A/C Relay circuit malfunction
P1466
A/C Refrigerant temperature sensor /circuit malfunction
P1467
A/C Compressor temperature sensor malfunction
P1468
SSPOD Open circuit or Closed circuit fault
P1469
Low A/C cycling period
P1470
A/C Cycling period too short
P1471
Electrodrive Fan 1 Operational failure (Driver side)
EDC16C3 / SID802-804 - RAS actuator. Operating field / performance.
P1472
Electrodrive Fan 2 Operational failure (Passenger side)
P1473
Fan Secondary High with fans (off)
P1474
Low fan control Primary circuit malfunction
P1475
Fan relay (low) circuit malfunction
P1476
Fan relay (high) circuit malfunction
P1477
Additional fan relay circuit malfunction
EDC15C2-Coolant solenoid valve
P1478
Cooling fan driver fault
P1479
High fan control Primary circuit malfunction
P1480
Fan secondary low with low fan on
P1481
Fan secondary low with high fan on
P1482
SCP
P1483
Power to fan circuit Overcurrent
P1484
Open power to ground VCRM
P1485
EGRV circuit malfunction
P1486
EGRA circuit malfunction
P1487
EGRCHK solenoid circuit malfunction
P1490
Secondary Air relief solenoid circuit malfunction
P1491
Secondary switch solenoid circuit malfunction
P1492
APLSOL solenoid circuit malfunction
P1493
RCNT solenoid circuit malfunction
P1494
SPCUT solenoid circuit malfunction
P1495
TCSPL solenoid circuit malfunction
P15XX - Vehicle speed / Idle control and Auxiliary Inputs
P1500
Vehicle speed sensor Intermittent
P1501
Vehicle speed sensor Out of self test range
P1502
Vehicle speed sensor Intermittent malfunction
P1503
Auxiliary speed sensor fault
P1504
Idle air control circuit malfunction
P1505
Idle air control system at adaptive clip
EDC16C3 - Impact detection. Impact information sent by the air bag.
P1506
Idle air control Overspeed error
P1507
Idle air control Underspeed error
EDC15C2-Anti-boiling strategy activated
P1508
Idle control system circuit Open
P1509
Idle control system circuit Shorted
P1510
Idle signal circuit malfunction
P1511
Idle switch (Electronic control Throttle) circuit malfunction
EDC15C2-ECU supplied as +APC
P1512
Intake manifold runner control (Bank 1) Stuck closed
P1513
Intake manifold runner control (Bank 2) Stuck closed
P1514
High load Neutral/Drive fault
P1515
Electric current circuit malfunction
P1516
IMRC Input error (Bank 1)
P1517
IMRC Input error (Bank 2)
EDC15C2-Coded anti-start function
P1518
Intake manifold runner control (Stuck open)
ME7.4.4 - Stop lamp information.
P1519
Intake manifold runner control (Stuck closed)
P1520
Intake manifold runner control circuit malfunction
P1521
Variable intake solenoid #1 circuit malfunction
EDC15C2-Clutch sensor
P1522
Variable intake solenoid #2 circuit malfunction
P1523
IVC solenoid circuit malfunction
P1524
Variable intake solenoid system
P1525
Air bypass valve system
MM4.8P - Idle regulation stepper motor. Short circuit to positive or short circuit to earth.
P1526
Air bypass system
P1527
Accelerate warmup solenoid circuit malfunction
EDC16C34 - Alternator charge. Information alternator charge signal lower than minimum limit.(Battery voltage).
P1528
Subsidiary Throttle valve solenoid malfunction
P1529
SCAIR solenoid circuit malfunction
P1530
A/C clutch circuit malfunction
P1531
Invalid test - Accelerator pedal movement
P1532
IMCC circuit malfunction Bank B
P1533
AAI circuit malfunction
P1534
Inetia switch activated
P1535
Blower fan speed circuit range/performance
P1536
Parking brake switch circuit failure
EDC15C2-ESP plausibility
ME745 - Check brake light switch
EDC16C34 - Brake switch signal inconsistency between 2 brale pedal signals.
P1537
Intake manifold runner control (Bank 1) Stuck open
EDC15C2 - Accelerator pedal jammed. Strategy activated.
P1538
Intake manifold runner control (Bank 2) Stuck open
P1539
Power to A/C clutch circuit Overcurrent
P1540
Air bypass valve circuit malfunction
P1543
Air conditioning compressor cut-off circuit
P1549
P1550
PSPS Out of self test range
P1565
Speed control command switch Out of range High
P1566
Speed control command switch Out of range Low
P1567
Speed control Output circuit continuity
P1568
Speed control Unable to hold speed
P1571
Brake switch malfunction
P1572
Brake pedal switch circuit malfunction
P1573
Throttle position Not available
P1574
Throttle position sensor Disagreement between sensors
P1575
Pedal position Out of self test range
P1576
Pedal position Not available
P1577
Pedal position sensor Disagreement between sensors
P1578
ETC Power less than demand
P1579
ETC In power limiting mode
P1580
Electronic throttle monitor PCM Override
P1581
Electronic throttle monitor malfunction
P1582
Electronic throttle monitor Data available
P1583
Electronic throttle monitor Cruise disable
P1584
TCU detected IPE circuit malfunction
P1585
Throttle control unit malfunction
P1586
Throttle control unit Throttle position malfunction
P1587
Throttle control unit modulated command malfunction
P1588
Throttle control unit detected loss of return spring
P1589
TCU Unable to control desired throttle angle
P16XX - Computer and Auxiliary Outputs
P1600
Loss of Keep alive memory(KAM) power Open circuit
P1601
ECM/TCM Serial communication error
P1602
Immobiliser/ECM communication error
P1603
EEPROM malfunction
P1604
Code word Unregistered
P1605
Keep alive memory (KAM) test failure
Lucas DCN2 Driver's requirement. Short circuit to positive or short circuit to earth
P1606
ECM control relay O/P circuit malfunction
P1607
MIL O/P circuit malfunction
MM6LP - Speed limiter.
P1608
Internal ECM malfunction (Bosch system-Control.Coolant temperature alert)
P1609
Diagnostic lamp driver fault
P1610
SBDS Interactive codes
P1611
P1612
P1613
Configuration
P1614
P1615
P1616
P1617
P1618
P1619
P1620
P1621
Control module Long term memory performance / Immobiliser code words Not matched
MM6LP - System anomaly. Safety.
P1622
Immobiliser ID does not match / System anomaly
P1623
Immobiliser code word / ID number Write failure
P1624
Anti theft system
P1625
B+ supply to VCRM fan circuit malfunction
P1626
Theft deterent fuel enable signal not received / B+ supply to VCRM A/C circuit malfunction
P1627
Module supply voltage Out of range
P1628
Module Ignition supply Input malfunction
P1629
Internal voltage regulator malfunction
P1630
Internal Vref malfunction
P1631
Theft deterent Start enable signal not correct/Main relay malfunction (Power latch)/ Internal ECM fault / Configuration fault)
P1632
Smart alternator faults sensor/circuit malfunction
P1633
KAM voltage too low
P1634
Data Output link circuit failure
SIRIUS81 - Ignition on ECU supply control. Short circuit to positive
P1635
Tyre / Axle ratio Out of acceptable range
P1636
Inductive signiture Chip communication error
P1637
CAN link ECM?ABSCM circuit / network malfunction
P1638
CAN link ECM/INSTM circuit / network malfunction
P1639
Vehicle ID block corrupted or not programmed
P1640
Powertrain DTCs available in another module
P1641
Fuel pump Primary circuit failure
SID801 Piezo-electric injector, power stage.
P1642
Fuel pump monitor circuit High input
P1643
Fuel pump monitor circuit Low input
P1644
Fuel pump speed control circuit malfunction
P1645
Fuel pump resistor switch circuit malfunction
P1650
PSP switch Out of self test range
P1651
PSP switch Input malfunction
P1652
IAC monitor disabled by PSP switch failed on
P1653
Power steering Output circuit malfunction
P1654
Recirculation Override circuit malfunction
P1655
Starter disable circuit malfunction
P1660
Output circuit check signal High
P1661
Output circuit check signal Low
P1662
IDM_EN circuit failure
P1663
Fuel demand command signal circuit malfunction
P1667
CI circuit malfunction
P1668
PCM-IDM communications error
P1670
Electronic feedback signal Not detected
P1671
MM6LP - Cruise control.
P1680
Metering Oil pump malfunction
P1681
P1682
P1683
Metering Oil pump temperature sensor circuit malfunction
P1684
Metering Oil pump position sensor circuit malfunction
P1685
Metering Oil pump stepping motor circuit malfunction
P1686
P1687
Lucas DCN2 (DW8B) - Pump module not matched
P1688
P1689
Oil pressure control solenoid circuit malfunction
P1690
Wastegate solenoid circuit malfunction
P1691
Turbo pressure control solenoid circuit malfunction
P1692
Turbo control solenoid circuit malfunction
P1693
Turbo charge control circuit malfunction
SID 803 Starting and switching off of the engine controlled. Starting or switch-off requests absent or not valid.
J34P - Remote control wake-up inconsistency problem.
P1694
Turbo charge relief circuit malfunction
P17XX - Transmission
P1700
Transmission Indeterminate failure (failed to neutral)
P1701
Reverse engagement error
P1702
TRS circuit Intermittent malfunction
P1703
Brake switch Out of self test range
P1704
Digital TRS failed to transmission states in KOEO / KOER
P1705
Not in P or N during KOEO / KOER
P1706
High vehicle speed observed in Park
P1707
Transfer cas Neutral indicator Hard fault present
P1708
Clutch switch circuit malfunction
P1709
PNP switch Out of self test range
P1711
TFT sensor Out of self test range
P1712
Transmission Torque reduction request signal malfunction
P1713
TFT sensor In range failure Low value
P1714
SSA Inductive signiture malfunction
P1715
SSB Inductive signiture malfunction
P1716
SSC Inductive signiture malfunction
P1717
SSD Inductive signiture malfunction
P1718
TFT sensor In range failure High
BVMPMA (sensodrive gearbox)- Gear selctor signal coherence.
P1720
Vehicle speed (meter) circuit malfunction
P1721
Gear 1 Incorrect ratio
P1722
Gear 2 Incorrect ratio
P1723
Gear 3 Incorrect ratio
AL4 - Gearbox output engine speed signal fault. No signal.
P1724
Gear 4 Incorrect ratio
P1725
Insufficient engine speed increase during self test
P1726
Insufficient engine speed decrease during self test
P1727
Coast clutch solenoid Inductive signiture malfunction
P1728
Transmission slip error
EDC16C3 - Multiplexing. No communication with the automatic gearbox.
P1729
4x4 Low switch error
P1730
Gear control malfunction 2,3,5
P1731
1-2 Shift malfunction
P1732
2-3 Shift malfunction
P1733
3-4 Shift malfunction
P1734
P1735
First gear switch circuit malfunction
P1736
Second gear switch circuit malfunction
P1737
Lockup solenoid system
P1738
Shift time error
P1739
Slip solenoid system
P1740
Torque converter clutch Inductive signiture malfunction
P1741
Torque converter clutch control error
P1742
Torque converter clutch solenoid failed On
P1743
P1744
Torque converter clutch system performance
P1745
Line pressure solenoid system
P1746
Pressure control solenoid A Open circuit
P1747
Pressure control solenoid A Short circuit
P1748
EPC malfunction
AL4 - Exchanger management solenoid valve output fault. Open circuit.
P1749
Pressure control solenoid failed Low
P1751
Shift solenoid A performance
P1754
Coast clutch solenoid circuit malfunction
P1755
Intermediate speed sensor (ISS) malfunction
P1756
Shift solenoid B performance
P1760
P1761
Shift solenoid C performance
P1762
Overdrive band failed Off
P1765
Timing solenoid circuit malfunction
P1767
Torque converter clutch circuit malfunction
P1768
Performance / Normal / Winter mode Input malfunction
P1769
AG4 Transmission torque modulation fault
P1770
Clutch solenoid circuit malfunction
P1775
Transmission system MIL fault
P1776
Ignition retard request duration fault
P1777
Ignition retard request circuit fault
P1778
Transmission reverse I/P circuit malfunction
P1779
RCIL circuit malfunction
P1780
Transmission control switch (O/D cancel) Out of self test range
P1781
4x4 switch Out of self test range
P1782
P/ES circuit Out of self test range
P1783
Transmission Overtemperature condition
P1784
Transmission mechanical failure-First and Reverse
P1785
Transmission mechanical failure-First and Second
P1786
3-2 Downshift error
P1787
2-1 Downshift error
P1788
Pressure control solenoid B Open circuit
P1789
Pressure control solenoid B Short circuit
P1790
TP (mechanical) circuit failure
P1791
TP (electric) circuit failure
P1792
Barometer pressure circuit malfunction
P1793
Intake air volume circuit malfunction
P1794
Battery voltage circuit malfunction
P1795
Idle switch circuit malfunction
P1796
Kickdown switch circuit malfunction
P1797
Neutral switch circuit malfunction
P1798
Coolant temperature circuit malfunction
P1799
Hold switch circuit malfunction
P18XX - Transmission
P1800
Transmission clutch Interlock safety switch circuit failure
P1801
Transmission clutch Interlock safety switch Open circuit
P1802
Transmission clutch Interlock safety switch short circuit to Battery
P1803
Transmission clutch Interlock safety switch short circuit to ground
P1804
Transmission 4-wheel drive High indicator circuit failure
P1805
Transmission 4-wheel drive High indicator Open circuit
P1806
Transmission 4-wheel drive High indicator short circuit to battery
P1807
Transmission 4-wheel drive High indicator short circuit to ground
P1808
Transmission 4-wheel drive Low indicator circuit failure
P1809
Transmission 4-wheel drive Low indicator Open circuit
P1810
TFP valve position switch circuit / transmission 4-wheel drive Low indicator short circuit to battery
P1811
Transmission 4-wheel drive Low indicator Short to ground
P1812
Transmission 4-wheel drive mode select circuit failure
P1813
Transmission 4-wheel drive mode select Open circuit
P1814
Transmission 4-wheel drive mode select short to battery
P1815
Transmission 4-wheel drive mode select short to ground
P1816
Transmission Neutral safety switch circuit failure
P1817
Transmission Neutral safety switch Open circuit
P1818
Transmission Neutral safety switch Short circuit to battery
P1819
Transmission Neutral safety switch Short circuit to ground
P1820
Transmission transfer case clockwise shift relay coil circuit failure
P1821
Transmission transfer case clockwise shift relay coil Open circuit
P1822
Transmission transfer case clockwise shift relay coil Short circuit to battery
P1823
Transmission transfer case clockwise shift relay coil Short circuit to ground
P1824
Transmission 4-wheel drive clutch relay circuit failure
P1825
Transmission 4-wheel drive clutch relay Open circuit
P1826
Transmission 4-wheel Low clutch relay circuit to battery
P1827
Transmission 4-wheel Low clutch relay circuit to ground
P1828
Transmission transfer case counter clockwise shift relay coil circuit failure
P1829
Transmission transfer case counter clockwise shift relay coil Open circuit
P1830
Transmission transfer case counter clockwise shift relay coil short circuit to battery
P1831
Transmission transfer case counter clockwise shift relay coil short circuit to ground
P1832
Transmission transfer case differetial lockup solenoid circuit failure
P1833
Transmission transfer case differetial lockup solenoid Open circuit
P1834
Transmission transfer case differetial lockup solenoid short circuit to battery
P1835
Transmission transfer case differetial lockup solenoid short circuit to ground
P1836
Transmission transfer case front shaft speed sensor circuit failure
P1837
Transmission transfer case rear shaft speed sensor circuit failure
P1838
Transmission transfer case shift motor circuit failure
P1839
Transmission transfer case shift motor Open circuit
P1840
Transmission transfer case shift motor short circuit to battery
P1841
Transmission transfer case shift motor short circuit to ground
P1842
Transmision transfer case differential lockup feedback switch circuit failure
P1843
Transmision transfer case differential lockup feedback switch Open circuit
P1844
Transmision transfer case differential lockup feedback switch short circuit to battery
P1845
Transmision transfer case differential lockup feedback switch short circuit to ground
P1846
Transmission transfer case contact plate A circuit failure
P1847
Transmission transfer case contact plate A Open circuit
P1848
Transmission transfer case contact plate A Short circuit to battery
P1849
Transmission transfer case contact plate A short circuit to ground
P1850
Transmission transfer case contact plate B circuit failure
P1851
Transmission transfer case contact plate B Open circuit
P1852
Transmission transfer case contact plate B Short circuit to battery
P1853
Transmission transfer case contact plate B Short circuit to ground
P1854
Transmission transfer case contact plate C circuit failure
P1855
Transmission transfer case contact plate C Open circuit
P1856
Transmission transfer case contact plate C Short circuit to battery
P1857
Transmission transfer case contact plate C Short circuit to ground
P1858
Transmission transfer case contact plate D circuit failure
P1859
P1860
TCC PWM solenoid circuit electrical / transmission transfer case contact plate D Short circuit to battery
P1861
Transmission transfer case contact plate D Short circuit to ground
P1862
Transmission transfer case contact plate power circuit failure
P1863
Transmission transfer case contact plate power Open circuit
P1864
Transmission transfer case contact plate power Short circuit to battery
P1865
Transmission transfer case contact plate power Short circuit to ground
P1866
Transmission transfer case system concern - Setting required
P1867
Transmission transfer case contact plate General circuit failure
P1868
Transmission automatic 4-wheel drive indicator lamp circuit failure
P1869
Transmission automatic 4-wheel drive indicator lamp circuit Short to battery
P1870
Tansmission component slipping/Transmission mechanicl transfer case 4x4 switch circuit malfunction
P1871
Transmission mechanical transfer case 4x4 switch circuit Short to battery
P1872
Transmission mechanical 4-wheel drive Axle lock lamp circuit failure
P1873
Transmission mechanical 4-wheel drive Axle lock lamp circuit Short to battery
P1874
Transmission automatic hall effect sensor power circuit failure
P1875
Transmission automatic hall effect sensor power circuit Short to battery / 4wd Low switch circuit electrical
P1876
Transmission transfer case 2-wheel drive solenoid circuit failure
P1877
Transmission transfer case 2-wheel drive solenoid circuit Short to battery
P1878
Transmission transfer case disengaged solenoid circuit failure
P1879
Transmission transfer case disengaged solenoid Open circuit
P1880
Transmission transfer case disengaged solenoid short to battery
P1881
Engine coolant level switch circuit failure GEM
P1882
Engine coolant level switch circuit Short to ground
P1883
P1884
Engine coolant level lamp circuit Short to ground
P1885
Transmission transfer case disengaged solenoid Short to ground
P1886
4x4 Initialisation failure
P1890
Transmission 4wd mode select return input circuit failure
P1891
Transmission transfer case contact plate ground return Open circuit
P19XX - Transmission
P1900
OSS circuit intermittent malfunction
P1901
TSS circuit intermittent malfunction
P1902
Pressure control solenoid B intermittent short
P1903
Pressure control solenoid C Short circuit
P1904
Pressure control solenoid C Open circuit
P1905
Pressure control solenoid C Intermittent short
P1906
Kickdown pull relay Open or Short circuit to ground
P1907
Kickdown hold relay Open or Short circuit to ground
P1908
Transmission pressure circuit solenoid Open or Short to ground
P1909
Transmission temperature sensor circuit Open or Short to power or ground
P1910
VFS A pressure Output failed Low
P1911
VFS B pressure Output failed Low
P1912
VFS C pressure Output failed Low
P1913
Pressure switch A circuit malfunction
P1914
Manually shifted automatic (MSA) switch circuit malfunction
P1915
Reverse switch circuit malfunction
P1916
High clutch drum speed sensor malfunction
P1917
High clutch drum speed sensor Intermittent
P1918
Transmission range display circuit malfunction
P2002
P2021
CAN engine torque information. No signal
P2025
Engine speed signal. No signal
P2101
S2000PM1 - Motorised throttle control coherence
P2120
Intake air heating circuit
P2137
EDC16C3 - Accelerator pedal 1, signal consistency with pedal 2 signal
P2144
EGR valve
P2199
SID 803 Air temperature after exchanger signal. Coherence with the intake air temperature.
P2263
Multifunction switch signal fault. Intermediate position
P2299
Accelerator pedal blocked
P2408
EDC16C3 - Additive system. Fuel tank cap presence sensor.
P2562
SID 803.Turbo pressure solenoid valve. Valve position too distant in relation to reference value, (repeat value for turbo incorrect)
P2563
P3004
3rd piston de-activator
PXXXX - Miscellaneous non EOBD Codes
P05D2
C5 II Suspension Ecotech ECU - No communication with the steering wheel angle sensor. Value received incorrect. (Fault flagged during wake up of network).
306 1.4 LX MERIDIAN
oneday
found this on another site it may help this was under the code p1112
That code description for the injection system Bosch EDC15C2 (what you have) is incorrect.
Fault is likely to be the pressure regulator on the output side of the common rail pump.
James Sinclair B.Eng M.Sc MPhil MIET APM AffIMI C.Eng
Peugeot & Citroen Specialists
Beaumont Diesels
Member of the Institute of Motor Industry (IMI)
e-mail: jamesjohnsinclair [at] googlemail [dot] com
MSN: jamesj [at] blueyonder.co [dot] uk
306 1.4 LX MERIDIAN
stu9
x 8
Thanks for that...
The P0180 is what the lexia brought up, I'll clear it and try it again later
This pressure regulator and the side of the pump, is it a certain colour of if not, should be easy to find/see.....just wondering too if it can be cleaned or has to be replaced.
Mind you, after talking to Jim, he's sure it'll be the egr because of the sluggishness too
oneday
if you google the codes there is a lot about the p1112 code it includes the fuel rail pressure readings so you can check that also a couple of other things to check aswell but i have not seen anything about the egr but i wouldnot say that jim is wrong as he does this for a living. im just trying to give you some help im no expert with these things and you can find most answers on the net. i think if i were you i would try the egr blank first it sounds like the easiest and cheapest place to start. hope this helps you out a a little.
306 1.4 LX MERIDIAN
