First Post guys and girls on a familiar topic.
Need to fix a 95 ZX Diesel for a friend. It souns starter motor/solenoid related. Where is the starter motor in relation to the battery ( I haven't got my nose under the bonnet yet )
Thanks[?]
ZD Starter Problem
jeremy
oldfruitie
AndersDK
Before you replace anything Fruitie :
Be sure the gear selector is in neutral & handbrakes on.
Then use a testwire directly from battery plus pole to starter solonoid spade terminal.
If this makes the starter crank the engine OK, you then know you have a cable problem from ignition keyswitch to the starter solonoid.
Read this thread :
http://www.andyspares.com/discussionfor ... IC_ID=6579
Read this thread :
mikeg
Hi Anders
I've got a starter problem similar to this one. I started my 1.7 dtr turbo with no problem yesterday to get it ready for the school run, switched off and removed the key (the key was unusually stiff to come out) Went out to get the car nearer the house tried to start it and stone me, it wouldn't.On turning the key to rotate the engine, nothing happens not even a click from the starter solenoid. All the normal dash lights come on. the glowplug relay works, the headlights dont dim when I turn the key etc. I've not tried to sort it yet except to tighten the battery terminals but what in the ign switch could cause this or, any suggestions, please.
Mike.
Mike.
uhn113x
- x 3
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> what in the ign switch could cause this or, any suggestions, please.
Starter contacts - you need a new switch, Mike
