Hand brake cables FYI
KennyW
x 165
Unread post by KennyW »
Hi All,
Fitted 2 new hand brake cables today 1 1/2 hrs job total.
The bol was accurate in its description of removal and fitting, the only pain was feeding the O/S cable through the eyes above the steering rack.
It also explains the poor handbrake results at the MOT. The cables were badly affected by rust due to wear and not moving very well in their sheaths.
Kenny
C3 1.4 petrol (SWMBO)
x 695
Re: Hand brake cables FYI
Unread post by Mandrake »
Well done, having done it now myself its not as bad as it looks. :)
For me the biggest challenge was sourcing the correct handbrake cables (!!) and getting the balancer box off and back on again, also necessitating removing the heat shield above the cat - not easy on a V6 with its huge cat...some "reshaping" of the heat shield was necessary to get it off and back on again. :lol:
Where did you get your cables from, and which Xantia did you do the job on ?
x 94
Unread post by citronut »
i dont know about on a V6 but other XANTS i have fitted cables on i just gently bend the heat shield away enough to get at the balance box, but also never had to remove the balance box at all,
you just need to put your finger through the hole in the side of the box, and unhook the cable with your finger
Regards, malcolm.
x 695
Tried that, but the cat on the V6 is too big so you can't bend the heat shield away enough to get at the two mounting bolts. One of the mounting bolts also holds the support bracket for the corner of the heat shield, that bracket makes it almost impossible to get a spanner on the nut... I don't know what they were thinking when they designed it. :roll:
Also as far as I can remember there were no finger holes in the side of the box. Unbolting the box was the only way I could get access. Maybe its different on other Xantias...(I never had to touch the handbrake cables on my last Xantia)
Lighty
x 35
Unread post by Lighty »
Xantias, all good, wait till you do a C5. :rant2:
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
KennyW
x 165
Simon,
I got my cables from SRS in Leith but they are a Glasgow firm with 3 places in Glasgow area.
They were Quinton Hazel make and the correct length.
http://www.qh.com/shop" onclick="window.open(this.href);return false;
Here's a link to QH site worth a check.
Kenny
x 8365
Mandrake wrote:Tried that, but the cat on the V6 is too big
Yes, it's less of a cat and more of a tiger really...
I'm looking to need to do this job on the XM at some point. Easy or is it a normal XM complete 'mare of a job?
x 94
should've dont the cables before re/tigering it Jim :o :roll: :-D :wink:
Regards, malcolm.
x 8365
citronut wrote: should've dont the cables before re/tigering it Jim :o :roll: :-D :wink:
There's lots of things I should've done Malcolm :roll: :lol:
x 94
like us all i spoz Jim
Regards, malcolm.
