Spare wheel needed to borrow near Reading..
Northern_Mike
Hi all,
does anyone have a Xantia wheel with a road legal tyre on it near Reading that I could borrow for an hour? I'm convinced that the vibration on my car is caused by the rear wheels, but I need two to prove this.
I swapped the drivers side rear wheel for the spare, this made no difference. I swapped the passenger side for the spare, it made a considerable difference, but the wobble is still there. Obviously I only have one spare. I really want to try it with two wheels on that are not mine and see what happens. I don't really want to go to the expense of buying a scrap wheel, making sure there is a road legal tyre on it, then finding out it's not the cause after all..
Help!
Cheers
MIke
Help!
Cheers
MIke
- x 8362
Re: Spare wheel needed to borrow near Reading..
Got one here Mike...
Sorry, I know, not much use is it...
Northern_Mike
Friday ok for you James?CitroJim wrote:Got one here Mike...
- x 8362
Yes, absolutely perfect MikeRattiva_Mike wrote: Friday ok for you James?
I've sent you a couple of emails about Rattiva by the way
Citroenmad
- x 110
Sounds like a plan Mike, though swapping them front to back would probably change the situation for a steering wobble, if it were the rear wheels.
Just make sure the borrowed wheels are tired and tested
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 8362
I'll make sure I keep 'em awakeCitroenmad wrote: Just make sure the borrowed wheels are tired
Citroenmad
- x 110
D'oh!CitroJim wrote:I'll make sure I keep 'em awakeCitroenmad wrote: Just make sure the borrowed wheels are tired
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1450
The spare wheel on that car is probably out-of round, I had to use it coming back from France 18 months ago, and it caused noticeable vibration.
While I owned both that car and my current car, I swapped the front wheels from my current car with the rear wheels on that one, to make a set of 4 reasonably good alloys on the car that I was keeping. So the rear wheels you have are not the pair that was on the car when I was plagued with the vibration.
The vibration did not really change with a set of new tyres, it did improve with a new(ish) upper engine mount (the horizontal donut), but got gradually worse again after a few 10,000s of miles.
Northern_Mike
The vibration lessened when I used the spare on the N/S/R today.xantia_v6 wrote:The spare wheel on that car is probably out-of round, I had to use it coming back from France 18 months ago, and it caused noticeable vibration.
Sounds like I might have been sold a pup that some people knew had a fault, but didn't have the courtesy to warn me about before I bought it.
Citroenmad
- x 110
You've got me worried there MikeRattiva_Mike wrote: Sounds like I might have been sold a pup that some people knew had a fault, but didn't have the courtesy to warn me about before I bought it.
I didn't even consider it a fault, slightly annoying yes but I assumed its just a wheel/tyre.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
electronmirror
- x 31
Hello Mike,
If you are still looking to borrow a spare wheel I'm in Wokingham, tyre size is the same, mine's an estate as per signature.
Could do Tues, Wed, Thur or Fri.
PM me if I can be of help.
Ted
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
Northern_Mike
Hi Ted,
That would be great. What time on Tuesday? I'm off tomorrow, so ideal.
All the best,
Mike
Sent from my HTC Sensation Z710e using Tapatalk 2
All the best,
Mike
Northern_Mike
Thanks to the very nice chap Ted, we discovered two things today - the vibration went away when two different wheels were fitted on the back.
BOTH, not just one, of the new-looking Pirelli P6000s have bulges on them. No wonder it was vibrating..
- x 8362
Excellent news Mike!
Northern_Mike
Well. Sort of. £160 quid for tyres the same spec isn't exactly "Excellent news" Jim..CitroJim wrote:Excellent news Mike!
