Penetrating Oil Advice
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi all..
Advice on the best Penertraiting oil OTHER THEN WD40...
The issue we have is a partially siezed Steering UJ joint on an XM, but rather remove it, which is a bit more fiddley then a Xantia, try and inialate it in penetrating oil in a hope to free it, then coat it in grease..
So any recomends on an oil???
Cheers
A very sad...
1994 XM 2.1 d auto
x 694
Re: Penetrating Oil Advice
Unread post by Mandrake »
Not an oil, (in fact it's non oil based and non greasy) but when it comes to penetrating and freeing rusted bolts and mechanisms etc you won't find much better than this:
http://www.lpslabs.com/product_pg/lubri ... /LPS1.html" onclick="window.open(this.href);return false;
Only trouble is I'm not sure if its readily available in the UK, I still have a can I brought with me from New Zealand :lol: I guess I will find out soon as my can is nearly empty...
Edit: There is also an oily version of it that leaves an oily protective residue, although I haven't used that one much:
http://www.lpslabs.com/product_pg/lubri ... /LPS2.html" onclick="window.open(this.href);return false;
citroenxm
Fallen Hero
x 70
Cheers, its not for rusted bolts, its for UJ spindle joints that tend it sieze over long time...
A very sad...
1994 XM 2.1 d auto
Citroening
x 19
Unread post by Citroening »
This Deblock Oil is the best we've ever had Paul:
http://www.innotecworld.com/products/gr ... oductid=84" onclick="window.open(this.href);return false;
Innotec do some great stuff - their double sided tape is second to none and perfect for if you're, eg, sticking side mouldings on cars etc. THE best...
Franklin
neil123
Unread post by neil123 »
Plus Gas? Was all the trade ever used, a few years ago?
Deanxm
x 87
Unread post by Deanxm »
plus gas is the pups nuts, wd40 is utterly useless as a penetrating oil, or anything really.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Acetone and ATF. Mix fresh, use promptly, applied with a brush. Once it's moving, start going up in oil weights.
citroenxm
Fallen Hero
x 70
Deanxm wrote:plus gas is the pups nuts, wd40 is utterly useless as a penetrating oil, or anything really.
D
Plus gas available in a spray canister though?? I can squirt a can of Plug gas from the wheel arch.. Ill need to reach into the UJ, which on the XM is not as easy as the Xantia, so If its available in a pressurised can that would be good...
A very sad...
1994 XM 2.1 d auto
gadgetgricey
Unread post by gadgetgricey »
C8 - Petrol Auto (Love the electronic doors)
Xantia Hdi Exclusive Estate (gone but not forgotten)
Deanxm
x 87
gadgetgricey wrote:Hopefully this is what you are after
- Dave -
There is the answer :lol: , plus gas the hell out of it then drown it in engine oil or 3 in 1, grease wont be much cop, it will just sit on the outside of the joint and attract muck.
D
XM Prestige PRV6 92
citroenxm
Fallen Hero
x 70
Ah, I guessed the Grease would hold in the the plus gas or what ever, and hold out any dampness etc...
Thanks people... And Dave!
A very sad...
1994 XM 2.1 d auto
Sam KS
Unread post by Sam KS »
Würth Rost-Off, but you'll have to speak to some one in the trade as Würth don't do retail.
Citroën Xantia 75th Anniversary Limited Edition
x 94
Unread post by citronut »
diesel is a good penetrating fluid also,
Regards, malcolm.
uhn113x
x 3
Unread post by uhn113x »
WD40 isn't a penetrating oil and neither does it purport to be.
Equal parts of DERV, paraffin and LHM?
Mike in West Yorks
1982 GSA Pallas
1982 Dyane
1997 ZX Dimension
x 94
uhn113x wrote:WD40 isn't a penetrating oil and neither does it purport to be.
its not even and oil it a moisture replant
Regards, malcolm.
