Hi all hope everyone is well, I've noticed that when I brake hard and come to a stop I can here a water swooshing sound coming from the left side of the car, I presume it's water inside the sill, are there drain plugs? Has anyone else experienced this?
Chris.
Water swooshing sound when coming to a stop!
cc101
Xantia 1.9 TD 1993 (sinker)
red_dwarfers
- x 58
Re: Water swooshing sound when coming to a stop!
I've had this in my Xantia before. I think it was in the sill too. There are rubber grommets along the bottom, I took one out to drain the water. I'm sure there must be a drain hole somewhere but it never happened again in mine so didn't look.
I imagine door could be another culprit but I think there are proper drain holes in that.
Kev
'19 C4 Cactus 130 Flair
cc101
Cheers Kev, will take a closer look when the weather dries up!
Chris.
Chris.
Chris570
- x 36
don't forget fuel in the tank
i can hear it on my HDi every now and then, only really when over 3/4 full
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Northern_Mike
It's either water in the sill - I had this in my first Xantia. I couldn't find a drain plug, though it appears I was not looking correctly reading the other replies to the thread. I just made a hole in the sill to drain it out. I coated it with jenlolite, then hammerited it and put a bung in. I wrote the car off shortly afterwards, so I'll never know if it lasted or not.cc101 wrote:Hi all hope everyone is well, I've noticed that when I brake hard and come to a stop I can here a water swooshing sound coming from the left side of the car, I presume it's water inside the sill, are there drain plugs? Has anyone else experienced this?
Chris.
As Chris says, it could also be fuel slosh if you've driving around 3/4 full..
