change a set of spheres
phoneblower
Re: change a set of spheres
Hi the oil used was Total 75W/80 oil put in through the reversing switch. But the gear change has not improved at all.
99 Xantia 2.0HDI
CX Athena 2.0
GS 1200 estate
CX Athena 2.0
GS 1200 estate
- x 3298
Have you been able to identify which gearbox you have?
phoneblower
Hi I have been able to see the reversing switch and it is mounted vertically so I think it is a ML5T.
99 Xantia 2.0HDI
CX Athena 2.0
GS 1200 estate
CX Athena 2.0
GS 1200 estate
- x 8427
If you've determined it's a 110 HDi then no question about it being an ML5T
phoneblower
Well it has a inter-cooler so it must be a 110HDI as I have been told the 90 does not have one? I must admit though I am not very up on diesels as it is the first that I have owned
99 Xantia 2.0HDI
CX Athena 2.0
GS 1200 estate
CX Athena 2.0
GS 1200 estate
- x 8427
That's correctphoneblower wrote:Well it has a inter-cooler so it must be a 110HDI as I have been told the 90 does not have one?
