multimeter
froggy
(Donor 2026)
x 4
multimeter
Unread post by froggy »
Hi, Iam about to test the blower motor on my Xantia, with a digital multimeter. I have never used one before. My question is where do I set the middle dial? as there are numbers both left and right of the dail , rising from 200m up to 1000 onthe left and 750 on the right . any help greatfully received, Terry . :oops:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
reblack68
Re: multimeter
Unread post by reblack68 »
Assuming it looks a bit like this
You are probably looking for Volts, and on the car this is DC Volts- the V range on the left here. The V range on the right is AC Volts, the symbols beside the letter V tell you this. You choose the lowest range that will include the voltage you expect- for a 12V system that will be 20 in this case.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
