Q re: DS Engine Rotation Direction
sonoramicommando
x 5
Unread post by sonoramicommando »
A bit of a n00b question:
Most of car engines turn clockwise looking at the front of the engine as far as I know, of some exceptions (hondas etc) - as for DS/ID and 15's, where is the "front" of the engine, given that gearbox is located in front of the engine - the clutch end or the bulkhead end?
cheers
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You crank them clockwise, so at the timing chain end they do rotate contrary to most engines.
sonoramicommando
x 5
Re: Q re: DS Engine Rotation Direction
fascinating!
so they used ccw engines from 15's til cx, correct?
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
x 694
Unread post by Mandrake »
I believe that while the CX engine is basically a DS engine (at least the push rod versions) it does in fact rotate in the opposite direction to the DS engine to accommodate the transverse gearbox layout...
sonoramicommando
x 5
^ doesnt that depends which side of the engine the gearbox sits? - i believe you but that doesnt necessarily dictate the rotation direction.
1982 GSA Pallas
A couple of bikes
A boyracer car ;)
