Hi all..
I bought my Xantia HDi exclusive year last november, so comming up to two years. When I bought the car it had 156k on the clock, and had recently just had the four CORNER spheres replaced..
Now recently, the front is getting not hard, but bouncy onthe front... I dont like it! Its not the electro valves as the car has the E Crofting kit, and they function correctly, buzzing and cutting out etc as they should.
I changed the front centre sphere, only to find it was not flat, and it was a Genuine Citroen unit with the 3 dots and the Citroen badge on it.. I swapped it anyway.. still the same.
So Im asking .. Now the car is on 223,500 miles, would the front spheres after 70k need renewing again?? Is 70k acceptable for a life of spheres.??
s**t Suspension and spheres advice
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
citroenxm
- Fallen Hero
- x 70
Re: s**t Suspension and spheres advice
No i don't have a pressure tester.. ive not any corner spheres to mess about with.. or time either ...:-\
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8422
What does a good old bounce test tell, you Paul?
Is the hydractive working?
Chris570
- x 36
at 70k i would be suspecting spheres.....
don't forget of course that dampers can go.
don't blame Hydractive, it's lovely
(I know you know all of the above, for other viewers really....)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
citroenxm
- Fallen Hero
- x 70
I believe it is Jim.. when i press the dash button she goes noticeably goes harder..
front corner spheres it is then
anyone got some good non dead used ones then??
:-D:-D
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
