Hdi xantia s2 PAS pipe nightmares TAKING NOTE?? PIPE IS NFP!
Xaccers
- x 188
Re: Hdi xantia s2 PAS pipe nightmares TAKING NOTE?? PIPE IS
Yes she's S2
DIY sphere tool
DIY sphere tool
- x 8309
No need, you can swap the feed pipe boss on the pinion valve. The boss just screws in (21mm socket needed IIRC) and thus you can convert between rubber seal and flare with ease...citroenxm wrote: OR, bite the buillet and swap the pinion valve for an S1 valve...
citroenxm
- Fallen Hero
- x 70
You are joking Jim??!!! if i knew that i simply would NOT of messed with brazing ! wish you had told me that sooner..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Xaccers
- x 188
That would have been a brazen liecitroenxm wrote:You are joking Jim??!!!
DIY sphere tool
DIY sphere tool
- x 8309
Oh, I'm so sorry Paulcitroenxm wrote:You are joking Jim??!!! if i knew that i simply would NOT of messed with brazing ! wish you had told me that sooner..
Look at it this way; you've now learned a valuable skill in brazing that's going to be increasingly useful.
Oh Xac, that's terrible and it's not making me feel any better for letting Paul down so badlyXac wrote: That would have been a brazen lie
- x 94
think of it this way Paul you have learned a new trickcitroenxm wrote:You are joking Jim??!!! if i knew that i simply would NOT of messed with brazing ! wish you had told me that sooner..
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
no Malcolm.. i bloody haven't! i couldn't braze the two damm parts to save a life! the two pipes just wouldn't go no matter how clean i got them..
i got soo peeeed by it i decided to take my last complete s2 pipe off the last spares car..
upon removal this one too broke through rust!..
so i ended up dooing what i CAN do.. join with union and straight line joiners .. this last pipe broke on a straight part not on the curved part where the others had.
so moral of this got the pipe all joined up with unions and its all up and running.
Luckily the PAS pipe is 4.5mm and I have 4.5 dies. the only other pipe that is 4.5 is the front to rear brake feed pipe..
Subject now closed. I hope i don't need to do another in the end. Three weeks to sort it from trying S1 pipes and pinion valve conversions to ending up back with a s2 fitted pipe with pleanty of underseal on it...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8309
Paul, when you come down to lay spanners on my XM I'll teach you how to braze properly... Bring the remains of your bad pipes with you and we'll make a good 'un for you
citroenxm
- Fallen Hero
- x 70
Hi Jim.. Im thinking of a day trip or something when yur ready .. ill leave here at 7am spend a few hours with you then come home..on a Friday or something..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8309
Sounds excellent to me Paul. Nominate a Friday and off we gocitroenxm wrote: ill leave here at 7am spend a few hours with you then come home..on a Friday or something..
citroenxm
- Fallen Hero
- x 70
Okay will do.. ill be in touch...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 8309
Great stuff Paulcitroenxm wrote:Okay will do.. ill be in touch...
