C5 2.2 HDi Auto - High fuel consumption?
SaabC5
Re: C5 2.2 HDi Auto - High fuel consumption?
Stick to the earlier 8v 2.0HDi if you don't want a DPF, check the engine cover for the 16v badging to be sure. Have you considered taking the FAP off the 2.2?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1240
I would agree, 8 valve engines were made until about 05, as far as I know none had DPF in fact the 90 bhp version doesn't have a DMF either
Monkeyfeet
Have you tied the swirl valve ball joint down? - With it just flapping engine performance can be erratic, cable tie-ing it pointing towards bulkhead gives back low down perf so you pull skin off rice puddings when pulling away. Fuel consumption won't be affected either.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
waynedance
- x 8
So what mainly causes the problems with the DPF's? is it letting the Eolys run dry, lack of servicing? short trips to shops and back?SaabC5 wrote:Stick to the earlier 8v 2.0HDi if you don't want a DPF, check the engine cover for the 16v badging to be sure. Have you considered taking the FAP off the 2.2?
Had my 2.2 for 2 years and only related warning I have had is "additive minimum level", the additive tank was refilled within two days. I do travel approx 38 miles a day with approx 8 miles on duel carriage way at 65mph+.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Longyear
Hi, yes, it's secured towards the bulkhead, so no issues there, and good performance and torque.Monkeyfeet wrote:Have you tied the swirl valve ball joint down? - With it just flapping engine performance can be erratic, cable tie-ing it pointing towards bulkhead gives back low down perf so you pull skin off rice puddings when pulling away. Fuel consumption won't be affected either.
Thanks for the info - if I decided to get another C5 it would definitely be a non-DPF 110 model (90bhp is just too underpowered for this weight of car in my view).
Oh absolutely. It's on my list but having recently being made redundant I cannot afford £300 at the moment but when circs change it'll be the first thing I get done.SaabC5 wrote:Have you considered taking the FAP off the 2.2?
Like Waynedance, I haven't had any DPF issues yet, but that's because my C5 had a new DPF and Eolys 2 years ago ..... but I know problems will start to occur the older the DPF gets and the more it gets blocked up over time. Awful, awful things. Hope the Eurocrat that sentanced our diesel cars to suffer with these completely inefficient DPFs is proud of his/her work.
David.
(15) Citroen C1 1.0i 12v Feel
(05) Citroen C2 VTS
(05) Citroen C2 VTS
SaabC5
waynedance wrote:So what mainly causes the problems with the DPF's? is it letting the Eolys run dry, lack of servicing? short trips to shops and back?SaabC5 wrote:Stick to the earlier 8v 2.0HDi if you don't want a DPF, check the engine cover for the 16v badging to be sure. Have you considered taking the FAP off the 2.2?
Short runs are the culprit, the DPF never gets up to operating temperature to burn the carbon deposits away. Thats why long runs are essential to FAP/DPF fitted cars, the EOLY's fluid allows the carbon to burn away at a lower temperature than it would otherwise.
corsehf
Why £300?, I removed mine myself and got a member on this forum with a lexia to turn the DPF off, beer tokens were exchanged and job done.
Where are you based?
Andy
2003 C5 2.2HDi Exclusive SE Est
2001 C5 2.2HDi SX Est (gone to C5 Heaven!)
2001 Omega 2.2DTi Est (stolen by Ex!!)
1997 Xantia 2.1TD SX
1994 ZX TD Volcane
Lancia Stratos Replica
1994 ZX TD Volcane
KevMayer
I'd like to remove my DPF and I have a Lexia.
Is there a definitive guide on how to get rid of it?
Cheers, Kev
HaydnR
Correct me if I'm wrong but I didn't think lexia could remove dpf settings, I used ECUsafe and a galletto cable. If there is not a guide already written I will post one.
'02 c5 2.2 hdi exclusive
corsehf
A Galletto cable (whatever that is!) is required).
As I don't have a Lexia, another Forum member did the job for me and from memory, it was just a case of telling the car that the DPF is no longer fitted.
The DPF was then removed, the inners knocked out and the sensors (top of bulkhead) unplugged.
It seemed that simple but probably wasn't!
Andy
1994 ZX TD Volcane
1994 ZX TD Volcane
KevMayer
I think DPF removal is mentioned in several posts but there's not one overall description.
A full guide would be really appreciated.
Cheers, Kev
Monkeyfeet
Edging slightly off topic I realise: I've removed my dpf/fap and would be happy to help write a guide to others. It's the 'proof' reading side from someone who hasn't done the removal that would really be useful.
Longyear
That guide sounds great Monkeyfeet
For me, I do basic servicing and the odd job, but I've never even taken an exhaust off, and don't have Galleta or a Lexia, so I reckon I'd rather punt up the cash and get a reputed specialist to do it. OR.... if anyone in the North East was happy and able to do it for me, and was 100% sure they'd not leave existing "anti-pollution / fuel additive" error messages on (I think this only happens when people remove the DPF innards, map out of the ECU, but forget to unplug the sensor), I'd be really happy to pay a good price....
I am in DH6 2BF (County Durham, near A19 / East Coast".
Cheers.
Cheers.
David.
(05) Citroen C2 VTS
(05) Citroen C2 VTS
Monkeyfeet
Hi Longyear, sounds like you've come round to the idea of having ( hopefully) a forum member help you to take off the DPF!
With a bit of luck it'll be when and not if someone local does it. I'd like to send the raw notes to go through when you do the job to help me correct any mistakes etc if you wouldn't mind?
You're right about the error messages appearing if you knock out the filter but don't reprog.
Longyear
Cheers, yes that sounds fine.
But as I said, I'm not equipped or confident to actually do it myself, but if a forum member was confident to do it (for which I'd happily pay for their time), I could then potentially follow your guide as the job progressed.
David.
(05) Citroen C2 VTS
(05) Citroen C2 VTS
