xantia rsdio code
crooser
xantia rsdio code
Unread post by crooser »
i can't log on to the radio code site so would anyone know the unlock code for the following blaupunkt radio in a 97 1.9 xantia with the following numbers? BP2775T9626791,part number,7 642 775 394.it's a 3030,phi/c 96 133 45780.the code i got from citroen didn't work so it can't be the original unit.for any help,many thanks.
Rivendell
Unread post by Rivendell »
Keep trying mate.... the site came up trumps for me, cos the code I got from the breakers yard was wrong.
reblack68
Unread post by reblack68 »
Both Blaupunkt calculators I have give two numbers for that serial- 2156 and 0156. Does that make sense?
crooser
reblack 68.i don't know how you worked those codes out but they didn't work.the correct code that worked is 9334.please note that unless you are 100% sure of a code you may be locking someone's radio up.
reblack68
I'm well aware that an incorrect code could lock up a stereo, but my attempt was no less wrong than the main dealer's.
I bought a set of calculators on Ebay, which I subsequently found free on http://www.members.lycos.co.uk/dsy8/ The Ford one worked on two units and I had no reason to doubt that the others would work. Are you sure you got the serial number right?
I'm sorry if my post implied that I was 100% sure about the code.
crooser
reblack68.a lot of people are using those calculators and i have seen many good results on the decode sites,in fact a great percentage give the right code.i didn't mean to criticise,i was just warning folks to take care.
