Hi
Iv had my 2004 c2 vtr plugged into a computer today due to an airbag fault. The guy with the computer saids it's the right hand connector below the drivers seat. Iv now taken the connector off and re terminated all connection in a temporary connector bloc. The air bag fault hasn't gone away! What else can I do? Could it be else where?
Thanks in advance for any help
C2 airbag problem
- x 1044
Re: C2 airbag problem
What was the actual fault code ? did the fault code point to a lateral airbag circuit fault or a pre-tensione circuit fault ?
superspudking
He diddnt give me a fault code just pointed out the connector. I will call him in the morning and ask what it was.
superspudking
There seems to be no one at the garage. Is there a way I can test the circuits?
superspudking
Ok so I have removed the car seat. The connector with the fault is going to the airbag on the seat. i used a multimeter on the connector (seat side) and i have continuity between the brown and blue wires. Is this normal or does it mean the airbag is faulty? how can i test to see if the airbag needs replacing?
thanks
thanks
superspudking
and is it safe to check out the wiring while its diconnected? i dont want the airbag blowing up in my face
