Xantia Window Problem
Timmy69
Unread post by Timmy69 »
Hi
Just got a Xantia 2.0L SX Hdi and one little thing thats annoying me is that the drivers side window starts dropping whilst driving.The most it has ever dropped is around 5 or 6 inches,so i don't think it has come off the guides or whatever their called.
Any Help Appreciated
Thanks in Advance
Timmy
P.S Make it as simple as possible please guys :)
x 1237
Re: Xantia Window Problem
Unread post by Peter.N. »
Does the motor shut it OK?
Timmy69
Hi Mate
There is noise coming from the motor and it seems to be trying to lift the window but it won't go up.
Napoleon
x 4
Unread post by Napoleon »
Whatever you do, don't do what I did and wreck the whole bloody affair by getting angry with it.
Honestly - I don't know the answer, but sure got fired up wrestling with it. If the car's a good 'un generally, it's worth having it looked at professionally, IMO.
My problem at the time with M289 was the rear o/s passenger door window. Never got it sorted, just lived with it.
Gone, but never forgotten...
DSC05098 by Tim Redberry, on Flickr
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
x 1237
Sounds as though the cable has broken, I think you can still get repair kits from ebay. Yes you can:
http://www.ebay.co.uk/itm/XM-XANTIA-SAX ... 2321d213fb" onclick="window.open(this.href);return false;
Timmy69
Peter.N. wrote:Sounds as though the cable has broken, I think you can still get repair kits from ebay. Yes you can:
Is it an hard job to do ?.
Also the rear door panel has a few bits missing like the speaker grill and the door lever...can these parts be sourced seperately or will i need a complete door card?
Will be taking the front door card off in the morning and hope its just the cable.
Thanks For the advice guys,and thanks for the link Peter :)
Timmy
x 1237
It depends on your DIY skills, its fairly straightforward but a bit fiddly, you have to take the motor assembly out of the door first, Have you got a Haynes manual, if not I would get one.
You may get the door bits from a breaker but you will probably have to buy a complete panel , if its the wrong colour you can change the bits over.
http://www.ebay.co.uk/sch/i.html?_trksi ... s&_sacat=0" onclick="window.open(this.href);return false;
Timmy69
Thanks Peter Gonna Try The Breakers Tomorrow.
Does the panel have to come from a HDi ?
Timmy
x 1237
I would think that the fitting would be the same but the trim might be different.
Timmy69
OK Thanks For The Help Peter
