addo
- Sara Watson's Stalker
- x 95
Deanxm
- x 87
Re: Citrojim's Xantia and XM Tales
Jim, access to the back of that panel is pretty good if you take the wheel and arch liner off you can reach right up to the rear quarter light, worth having a play with a spare panel first, i got a wing from a scrapyard and beat it in then had a go at dressing it back out, you can reserect some really bad damage with patience and some simple tools, a friend of mine has had a couple of Boxsters which were accident damaged, the latest ame off the road and rolled destroying the left side and he beat the wing back out to look like new, when he got it that panel looked like you had given an angry teen a hammer and asked him to do his worst.
now it looks like its never been touched.
D
D
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Chris570
- x 36
Jim,
Once again so so sorry but, I have been looking into this, it's a technique called 'spreading'. Bear with me on this, what you need to do is get your second and third finger and place them over the scratch (or gash) and then applying gentle pressure move your hand from side to side over the patch, eventually you'll see with careful rubbing you'll get the desired result.
Go on, try it, go and rub one out now
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8422
Sounds like Reiki healing for cars to me
This shows what a bunch of pikies they are. This is a picture of a repair they made to Liam's broken rear-view mirror...
The rubber glove was the master stroke...
Deanxm
- x 87
Chris has missed one vital step, after rubbing with the fingers as stated (which you should have licked by the way) you then rub said scratch or gash with your sleeve creating an immediate and full repair.
D
D
XM Prestige PRV6 92
Chris570
- x 36
you are quite right but sometimes the area may have become pre-moistened, I have known people to use fists but it is my understanding that this will do Irreversible damage.Deanxm wrote:Chris has missed one vital step, after rubbing with the fingers as stated (which you should have licked by the way) you then rub said scratch or gash with your sleeve creating an immediate and full repair.
D
Remember, gently does it
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
addo
- x 95
- x 8422
I could say this is getting out of *hand* but I wont....
Until now I've been using my laptop-based Lexia 3 to diagnose the XM. To me it seemed faintly wrong so as a nice little relaxing task I made up a special 2-pin lead for my ELIT so I could use that. Seems much more fitting to use a contemporary diagnostic tool for the job.
It's a lot less faffing around than the Lexia, no waiting for Windows to boot and no faffing around with VINs and ORGA numbers. It's just straight in like a rabbit up a burrow
Here it is in action:
citroenxm
- Fallen Hero
- x 70
Hi jim/Chris
Before this topic went on about body work after you put you had done a good sort out I asked should i get the corner of my shed sorted now or after cxm.. somehow that Q got overlooked... so .. do i need to get sorting or we ok till after cxm for your sorted stuff????
you said you had a van full ..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Deanxm
- x 87
I thought all this was going to stopIt's just straight in like a rabbit up a burrow
D
XM Prestige PRV6 92
- x 8422
One can hope DeanDeanxm wrote:I thought all this was going to stopIt's just straight in like a rabbit up a burrow
D
Paul, there is a trailer load and an XM-load to bring to CXM not forgetting some stuff already stashed at Chris's gaff. What I'd propose is what doesn’t sell could be valuably stored on the Island...citroenxm wrote:Hi jim/Chris
It would be a shame just to sling it... We can discuss at CXM...
Quite happy to pay a peppercorn rent for the space... I can recommend Chris and Liam as top blokes for tidying up and sorting out too...
Xaccers
- x 188
Don't forget there's Juliet's bodywork, and you can have fun with Jenny's dented door once I've replaced it
Plenty of panels for you.
Now, you just need to get super good at welding and sort out the door join rust on Cassy
DIY sphere tool
DIY sphere tool
- x 8422
Sounds like you have plenty for me to do Xac
Xaccers
- x 188
You can have fun with the girlsCitroJim wrote:Sounds like you have plenty for me to do Xac![]()
DIY sphere tool
DIY sphere tool
Citroenmad
- x 110
Oh, are we going to have a bit of a Citrojim boot sale going on at the CXM?
I'll see if I need any bits
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
