How do the leather seat...
robin92
Unread post by robin92 »
look in Xantia serie 2 activa?
Like this?
http://www.google.se/imgres?num=10&hl=s ... x=58&ty=42" onclick="window.open(this.href);return false;
BTW!
Should Xantia break seire 2 interior fit Xantia serie2 Saloon (dont really now the english name, but not break)
Xantia Activa 2.0 tct -96, Xantia Activa v6 - 00
Sorry for my bad English;)
x 5673
Re: How do the leather seat...
Break is acceptable Robin but they are known as estate cars here.
Xantianut
x 124
Unread post by Xantianut »
Ay up!
Front seats are identical but rear seats from saloon / break are different.
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
robin92
Xantianut wrote:Ay up!
What are diffrent dont fit at all?
Need fast answear because I going to buy a interior tomorrow from a break
andmcit
x 30
Unread post by andmcit »
Totally different backrest between Break and Hatchback saloon. The moutings are like these:
estate/break
saloon
Yes, I need to get the vacuum cleaner fixed... :roll:
Andrew
Nothing moves you like a Citroën
robin92
THANKS!
Spaces
Unread post by Spaces »
robin92 wrote: BTW!
Robin92, many British Citroenistes use the term 'break' for an estate car when referring to Citroens. It makes them sound as if they know their stuff! At other times they will say 'Familiale' to distinguish another Citroen estate from its other brethren.
PeterN: "Honest John's forum put the last nail in the coffin of owning a 2000- car. Many were still servicable, but CR, DMFs and needing fault codes read because your horn doesn't work - no thanks. All my life I have generally understood cars - until now."
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I think if you "skin" the rear seat it should be possible to install on the other type frame. Small patches would need placing to cover the latch cut out areas. Hog ring pliers make the refitting easy.
