Xsara BE3 Clutch Trouble
dandare1980
Re: Xsara BE3 Clutch Trouble
Unread post by dandare1980 »
Thank you for all the helpful comments.
I've found some Valvoline HP PC Gear Oil 75W80 on Eurocarparts website, which suggests it's for Citroen/Peugeot applications, although doesn't say it's BV compatible:
http://www.eurocarparts.com/ecp/p/car-a ... &1&cc5_868
If I enter the "midmonth30" code at the checkout it means I can currently buy 2 litres for £11.24 inc. VAT.
Dan.
1998 Citroen Xsara 1.9 D Estate (XUD9A indirect injection engine DJY with Bosch XUD 211 injection pump).
x 8417
That's the stuff Dan :) Order it quick!!!
dandare1980
Thanks Jim, it's ordered and on the way.
Others have recommended replacing the input shaft seal too, is this accessible inside the bell housing if the gearbox is slid to one side during clutch removal, or will I need to drop the box out to do this?
I've nearly got all the bits.
Dan.
x 1492
You'll need to box out to do the input seal - and you will also need to remove the release arm - see my earlier post about that!
dandare1980
Thanks for confirming that Richard, I may decide not to venture that far if it becomes a pain to remove the gearbox completely.
Dan.
flying clutchman
x 3
Unread post by flying clutchman »
should only need to replace the input shaft seal(it comes complete with sleeve, stocked by ecp) if the sleeve has been wrecked by the release bearing chewing it up. (very common). You don't need to remove the release arm to change this, just lift it up and twist it. Dropping the box out is by far the easiest way to do the clutch, on the non-turbo it's a pretty simple job as gearboxes go. I normally allow 3 hours, so 5 should be a realistic target for someone not familiar with the task.
dandare1980
Ok, I think I better pick one up as a precaution as I'm not sure how badly knackered it all is inside that bell housing.
I've learnt this morning that the clutch release bearing slides back to rest on the shaft sleeve when not in action and the shaft can wear or become pitted if the bearing is wearing out. This apparently can then cause the release bearing to catch, twist, or jam and not fully return to its resting point, which can cause the clutch to slip. If the sleeve is worn it can also cause the clutch pedal to feel higher resistance or jerky and the bearing will not slide freely as it should (some of my symptoms)
My non-turbo appears to have good space around the gearbox, once you remove the battery it's the only thing left on that side of the engine.
I shall try and remove it after all.
Thanks for your help,
Dan.
dandare1980
In today's post I received a LUK RepSet Clutch kit comprising of a Friction Plate, Pressure Plate and a Release Bearing (£78.63), a pair of Gearbox Driveshaft Oil seals (£8.89) plus a pair of Fork Lever Bearings (£7.49).
UPDATE: Now got the Guide Bush/Primary Shaft Seal (£7.95), waiting for the transmission fluid to arrive.
What took me by surprise was how thin the friction plate material is, should it really look like a barely legal brake pad? Also, the yellow spring in the photo appears really flimsy, is that normal?
The clutch kit did not come with any grease, am I looking for high temperature stuff like lithium grease?
flying clutchman
x 3
Perfectly normal
dandare1980
Thank you flying clutchman,
It was a very daft question, but it's the first time I've seen one up close :oops:
Quite amazing to think that all of the engine's power is being transferred via that skinny friction plate.
Dan :)
x 1492
And it you haven't been abusing it you may well find that the plate that's in there doesn't look much different!
dandare1980
Right, eventually getting started after some set backs and procrastination!
Picked up some "MolyGrease" from GSF, hopefully this contains enough Molybdenum Disulphide (it's largely lithium based) to be good for use on the clutch parts.
A very thin smear I will add....
Setting the car up ready for draining the gearbox oil later.
Will update after the weekend to let you know of the outcome.
I've been offered 2 months of work today (came out of the blue), but I've got to start on Tuesday!
Nothing like the motivation of a deadline.
Wish me luck..........
EDIT: Quick silly question about the driveshaft seals, do I leave the plastic protection teeth in place after the driveshaft is fitted (see above in previous post)?
x 94
Unread post by citronut »
dandare1980 wrote: EDIT: Quick silly question about the driveshaft seals, do I leave the plastic protection teeth in place after the driveshaft is fitted
yes they stay there
Regards, malcolm.
dandare1980
Thanks Malcolm.
