Xsara Steering creaking when turning
compbuild
Unread post by compbuild »
Hi I have a 1998 1.9LXTD Xsara Hatchback, The problem is a creaking noise when I am turning into junctions or driveways, any ideas what the problem might be and is it easy to fix
Thanks for your help
edd001
Unread post by edd001 »
where is the creaking coming from.
compbuild
seems to be coming from down round the wheels
x 1431
Our ZX had a very pronounced creaking when putting lots of steering lock on (sounded like a wheel was about to fall off in multi-storey car parks[xx(]). I thought it was the strut top bearing, but the MOT was failed on split front wishbone rear bush (there was also some knocking by this stage!). Replacement of the bush (well the whole arm actually as it was just as cheap and a lot easier) cured it.
compbuild
I think it's had one of these already if I remember rightly it must wear through them in no time
rabenson
Unread post by rabenson »
My ZX has had a creaky stut top bearing for years - never seems to get any worse and is only noticeable at low speeds...
