is this the correct part?
john
Unread post by john »
need a offside oil seal for my gear box (BE3R)
here's a pic of what is there currently
and here's a listing for 1
http://goo.gl/2puHc" onclick="window.open(this.href);return false;
apparently it fits the BE3R but i get diferent numbers on CS
also appears that thats a bearing and not the actual seal?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
x 2938
Re: is this the correct part?
You're looking at the wrong page on CS, you need to look at the Differential Manual gearbox page, that is the right seal, well pair of seals actually.
x 94
Unread post by citronut »
as Gibbo says
i have just done a ckutch on a customers 306 which use's the same seals
i bought them from GSF i think they were without looking at the invoice £3.70 each plus VAT,
although the two in your link will fit
Regards, malcolm.
john
so that part with the "teeth" is an actual seal?
this is the correct part then
http://www.gsfcarparts.com/311pc0020" onclick="window.open(this.href);return false;
ir says fitment "left", is this correct even though its the driver side shaft?
Subaru Impreza WRX
Nissan Primastar
x 94
the two diff seals are both different sizes the smaller one is drivers side= O/S,
the plastic teeth are a guide to stop the drive shaft catching the seal,
here is part No.'s and dimensions of both seals part No. 3121 46 is the O/S
LEFT
3121 44
SEAL
40X58-10
- BE3R MANUAL GEARBOX
40X58-10
- BE3
40X58-10
- GEARBOX BE4R
RIGHT
3121 46
SEAL
29X47-11
29X47-11
- BE3
29X47-11
- GEARBOX BE4R
and here is price and part No.'s for both seals from citroen
0000312144 SEAL 9.03 GBP 10.84 GBP 10.84 GBP
0000312146 SEAL 10.62 GBP 12.74 GBP 12.74 GBP
Regards, malcolm.
